steering problem
Discussion in 'Gen 3 Prius Technical Discussion' started by barnabas, Apr 16, 2024.
  1. barnabas
    barnabas Junior Member
    53
    new hampshire
    I have 93,000 on my 2010 gen 3 prius and the stearing feels like it is sticking. Has anyone noticed that in theirs? I wonder about what it would cost to get it fixed.
    Thanks
    Barnabas
  2. PriusCamper
    PriusCamper Senior Member
    13,327
    5,393
    Pacific Northwest, USA
    This is usually low tire pressure... It's amazing how many people think they can go years and years without making sure they're keeping their tire pressure as high as possible. The higher the tire pressure the less sticky the steering, as well as way better MPG.
  3. barnabas
    53
    new hampshire
    Thanks for the reply. I wish it was was that simple. I check my tire pressure monthly and keep the tires at 3 lbs above the totota lable recommended pressures.
  4. ChapmanF
    18,880
    If you pull out the 60 amp EPS (electric power steering) fuse (look near the top outboard corner of the underhood fusebox, it's a big fuse) you can drive the car around some with manual steering. Expect a good upper body workout. It's a car with a heavy front end.
    Do you still notice a "sticky" feeling that way (adjusting for everything feeling, you know, harder)?
    That might be a clue whether you've got more of a mechanical issue, or something involving the power assist.
