Steering shaft question
Discussion in 'Gen 3 Prius Technical Discussion' started by Gourockian, May 15, 2023.
  1. ChapmanF
    19,020
    The reason the auto/boat/marine wiring practices join flexible wires with proper crimp joints rather than solder is to avoid the brittle joint resulting from solder.
    There are, of course, lots and lots of soldered joints in the car; they are just on circuit boards or in other places where things are fixed in place and flexing isn't an issue.
  2. Gourockian
    Gourockian Junior Member
    75
    23
    New Port Richey
    Yes, you are correct, with the emphasis on PROPER crimp joints. I've had mixed success using crimp connectors, even after investing in a decent crimping tool.
    In my experience, a properly cleaned and fluxed solder joint between two wires is far more reliable, particularly in a flexing situation, than a dodgy crimp where wires can be pulled out or corrosion can easily start. If someone is not capable of soldering correctly, by all means try the crimp method but to be honest, two wires twisted together and back on themselves and well taped up may be their best option.
  3. ChapmanF
    19,020
    Gourockian likes this.
  4. Lares_Mat
    Lares_Mat Member
    199
    59
    Amen!
