Steering wheel angle sensor
Discussion in 'Gen 3 Prius Main Forum' started by Sanal, Jul 25, 2019.
  1. Sanal
    Sanal New Member
    Chicago
    Hi everyone, after changing the clock spring on my 2010 Prius I have traction control light and check PCS on Tried to reset with a scanning tool but I couldn’t. Any thoughts about it ?
    Thanks in advance
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Did you buy a genuine clock spring or a cheaper one off of eBay?
    The cheaper ones do not have the best track record reported here, so something to consider.
    If the code does not reset, that means it is still an issue and will continue to be. You can always use Techstream and see what all of the codes are.
    Good luck and keep us posted(y).
    SFO and Sanal like this.
  3. Sanal
    Sanal New Member
    Chicago
    Thanks for your response. I brought the clock spring from eBay. I will try to replace it with the old one and report here the status.
    Thanks
    Raytheeagle likes this.
  4. Sanal
    Sanal New Member
    Chicago
    DB78C5AA-E00E-4EF1-B41F-2DECF41A8BCA.jpeg DB78C5AA-E00E-4EF1-B41F-2DECF41A8BCA.jpeg I replaced the old clock spring and the steering angle sensor error C1231 still there. I tried the paper clip trick and now I’m getting two more errors C1203, C1231 and C1345. I tried to reset it with Techstsream didn’t worked. Any solution? Posting the error code screenshot.
    Thanks
