Steering wheel bubble
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Markelli, Oct 18, 2020.
  1. Markelli
    Markelli Junior Member
    50
    South Florida
    What is the best product or way to fix this. I know the steering wheel is not leather. I’ve dried a hair dryer to no effect. Is there a product anyone can recommend? Thanks much!
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,495
    Taylors, SC
    I wrapped the plastic steering wheel on my Prius v 8 years ago and never looked back. It is as close to OEM quality as you can get. It is as good as the day I put it on.
    The only issue is that doing it right took more than two hours and a lot of patience.
  3. Markelli
    50
    South Florida
    Thank you but my steering wheel is heated and I’d hate to lose that functionality is there any other options I see some kids at AutoZone that repair leather etc. has anyone had any luck with those?
  4. Georgina Rudkus
    3,511
    2,495
    Taylors, SC
    That's the point. Heat, either from the heater or the Florida sun and VU kill plastic.
  5. Markelli
    50
    South Florida
    There has to be a way to smooth out the plastic bubble somehow
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    You could poke it with a pin and then glue it;).
    One option(y).
  7. Georgina Rudkus
    3,511
    2,495
    Taylors, SC
    Use a hypodermic needle, and inject a small amount of glue into the void.
  8. Markelli
    50
    South Florida
    interesting idea, I doubt I’m handy enough to try that lol
  9. Markelli
    50
    South Florida
    Ok got a new steering wheel! Now is there a wrap anyone knows that allows the heated steering wheel to still work?
  10. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I didn’t even know I had a heated steering wheel! But while we are speaking of that area.... I like the horn to tap easily and use it often for signaling pedestrians. It used to be that the horn ring came off easily and adjustment was quite easy. This is my 4th Prius and I am always fearful of loosening, pulling or prying anything on these plastic cars. Does that horncover pull off easily and is there an adjustment underneath.
    I have applied mild pressure but nothing happens. TY
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    If you still have the Base Model, you don't have a heated steering wheel. Neither do I.
    As for the horn, I can't say for sure. But I have had that stuff off on a Gen 2 to replace the clockspring. It required removing some trim and some screws to get it off. I didn't notice any adjustment. But then, the Gen 4 could be very different.
  12. Kenny94945
    Kenny94945 Active Member
    857
    433
    Sausalito
    2016 Prius v wagon
    From the photo I do not see a bubble, I see a cut.
    If a bubble, the needle and glue IMO is the best repair attempt.
    If a cut, the are leather bonding kits that you maybe able to blend in.
    A heat gun will be a tool asset for both repair attempts.
    Depending on your OCD :) , a replacement steering wheel maybe the only superior fix.
    And FWIW, drive naked, remove rings or wear gloves... half serious comment :)
    Good luck wished.
