Steering wheel clunk/looseness
Discussion in 'Gen 2 Prius Technical Discussion' started by Autmsky, Oct 20, 2009.
  1. Autmsky
    Autmsky New Member
    Hopewell,IL
    This is my first time in the forum. I have a 2006 Version 6 with 71,000 miles. I bought it 6 weeks ago with 68,000. I notice everytime I make a lateral pull on the steering wheel, I feel a clunk in the steering column like there is some movement there. This is a common move for me as I use the steering wheel as an assist out of the car. I can also feel this clunk at times on slow parking moves. I've seen the bulletins about loose/defective intermediate steering shafts as well as loose bolts there. All that is good and tight. I took it to the dealer who verified my concern, but in the end said they found nothing wrong. Is it normal for the power steering motor/module to have some looseness? This is my first Prius, so I don't know what's right and wrong. A comparison with another 2007 showed the same "clunk" feel in its column. Tell me what you folks experience.
  2. JayGoldstein
    JayGoldstein Member
    120
    Winnipeg, Manitoba, Canada
    My 06 has about 66,000 km (41,000 mi). I have experienced this "clunk", under the exact circumstances you've described.
    At about 8,000 km, I noticed an occasional clunk when turning at very slow speeds. The steering shaft was replaced @ 12,100 km, but the clunk was not eliminated. I took the car back and the steering yoke was replaced @ 17,200 km.
    I still could detect a clunk, and took the car in @ 17,600 km to have the Prius tech check the steering for any loose components. He reported all was well. He noticed the clunk, but said that this seemed to be characteristic of the Prius. He accompanied me as I test drove a used 05 and a new 07. Neither car exhibited the clunk. The tech then spent some time making sure that the alignment of the steering was correct. Whatever he did made a definite improvement in that the clunk occurred less frequently. Unfortunately, it was not eliminated.
    I've driven almost 50,000 km since then, and the clunk has not gotten worse (or better). It's an annoyance, but I've learned to live with it.
    I don't think it's "normal." If you find a solution, please let me know.
  3. Sezy
    Sezy Active Member
    431
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Sound like this?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
  5. JC91006
    16,672
    8,518
    The clunk is from a worn intermediate shaft, change that out and the clunk will go away.
    Sezy likes this.
