steering wheel defrost buttons on 2004 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kevin Cecchini, Jan 21, 2017.
  1. Kevin Cecchini
    Kevin Cecchini Junior Member
    44
    Clinton, Michigan, 49236
    Hello,
    My prius, purchased with 200,000 miles has an issue with the steering wheel. Nothing big, however, I am curious if there is a simple fix?
    The defrost buttons on the right of the steering wheel will not work. The stereo and temperature increase and decrease buttons on the left work just fine.
    Is this something as simple as a fuse, or is it something more as in worn out buttons?
    OK, thank you for your time and suggestions. It is greatly appreciated.
    Kevin.
  2. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    It sure sounds like the "clockspring", also known as the spiral cable. There are some good threads on that.
    Next thing to go will probably be the cruise control.
    Kevin Cecchini likes this.
  3. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    There cheap on eBay very easy. But when you remove the air bag there are two wire lift yellow lock pin and pull plug out take you time don't break the yellow plug .
