Steering wheel squeak
Discussion in 'Prime Main Forum (2017-2022)' started by Oskar, Dec 26, 2020.
  1. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    I've recently noticed a low level squeak coming out of the steering wheel where it meets the column. It happens when the wheel gently turns, mostly to the right. Sounds like something rubbing together, perhaps vinyl or plastic. Wondering if anyone else has had this issue, or what it might be. The car is a 2020 Prius Prime Limited, bought it in August. The car runs like a dream, but have to admit that darn squeak is driving me crazy! :censored:
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    I have not had any problem like yours with my 2020 PP LE. But on my previous 2017 PP Premium, I had rattles coming from the center dash that drove me crazy. It was a GPS antenna or something that was loose and hitting the plastic casing. A visit to a dealer fixed it free. Yeah, that's what a warranty is for.
  3. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    I had the same problem, but ended up trading in my Prius before dealing with it. The dealership I bought from is not very good with consumer relations. I had an early problem and wanted them to look at it. It was under warranty, but they said if they didn't find anything that the would have to charge me. What?? We settled that quickly.
  4. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    No one else has experienced the steering wheel squeak? I've made some recordings of it and will go to the dealership after the first of the year. Hopefully they can resolve it. And hopefully they would give me a lot of crap.
  5. luiset83
    luiset83 Member
    141
    2023 Prius Prime
    XSE
  6. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Many thanks for your reply. The situation has not occurred again, but if it does I will certainly refer to your situation. As I said, I also have recordings of the sound, albeit faint. Thanks again, most helpful!
  7. boostedGS
    boostedGS Junior Member
    45
    Los Angeles area
    I have the same issue, but it hasn't gone away. 2021 pp xle.
  8. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    It may be far more expensive to change tooling or modify the supply chain than to just pay to have a very small number of them fixed.
  9. boostedGS
    45
    Los Angeles area
    I had some fluid coming down my steering column area, I wonder if thats related to the squeak.
    Any of you guys that have the squeak also see some fluid (water/oily viscosity) coming down by the steering column?
    #9 boostedGS, Oct 19, 2021
  10. prime grip
    prime grip Member
    115
    56
    SO CAL
    Did your squeak ever go away ?
