Step on it! Have some fun.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ultraturtle, Aug 19, 2012.
  1. lensovet
    2,615
    496
    Burlington, NJ
    there is, it's called the European PiP
  2. ultraturtle
    108
    81
    Peachtree City, GA
    I get your point, but it distracts a little bit from my OP. My suggestion was not to "blow off the line" but to accelerate more agressively than most cars behind and beside you at 60% EV up to 25mph, 70% EV up to 34mph, and 80% above 34mph with virtually no penalty to EV range. Taking the worst case misinterpretation of my results would indicate a .5 mile total EV range reduction over the course of 17 accelerations, not just one, and would ignore the benefit of getting over 2 minutes of your life back in doing so.
  3. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Yes, I was agreeing with your OP, stepping-on-itat 60/70/80% in a Prius is a fine thing, and something every PiP Owner should enjoy and have some fun.
    52,773
    really? cool! why do they get stuff we don't and vice versa?
  5. lensovet
    2,615
    496
    Burlington, NJ
  6. bisco
    52,773
    i wonder what happens when you turn the heat or defrost on?
  7. bisco
    52,773
    charged up today and had no where to go. so i took a joy ride to burn off some juice. hit the back roads and really tore it up. this baby has some guliones!
    lensovet likes this.
  8. drinnovation
    2,027
    586
    65
    CO
    what does "guliones" mean? Google found nothing helpful to me.
  9. bisco
    52,773
    no idea, but it really describes the acceleration.:p
    Tracksyde and lensovet like this.
  10. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I'd prefer that. If someone can figure a way to switch the PWR button to behave like EV City mode, that would be an awesome hack. I wonder if it's as simple moving the wire from one pin on the ECU to another. Or maybe it's some sort of software setting via a hidden configuration menu or requires a special programmer.
    Anyhow, I really don't understand the point of a mode that makes it easier to start HV. A mode that makes it harder to start HV makes perfect sense, tho'.
    Drake, ultraturtle and lensovet like this.
  11. bisco
    52,773
    ^^ditto^^ must be their perception of americans. gotta have POWER! and maybe they're right, it was the first thing the salesman showed me, he got all giddy talking about it. i have never used it.
