Stereo strange screw head.
Discussion in 'Gen 3 Prius Audio and Electronics' started by BasemS, Nov 10, 2017.
  1. BasemS
    BasemS Junior Member
    Auckland
    Hello
    This is my first post :)
    I tried to replace my stereo and I found this screw head
    Any recommendations, please?
  2. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Maybe a security head so the local crack addict can't replace your stereo?
  3. RRxing
    RRxing Senior Member
    2,562
    1,840
    NEPA
    Probably a security screw. See if it's any one of these:
  4. Prodigyplace
    12,710
    11,848
    Central Virginia
    It may be one that is not seen in the US.
    BasemS likes this.
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    It probably requires a Toyota specialty tool.
  6. ChapmanF
    18,982
    Doesn't look original to me. Torx is about the most exotic head I've seen Toyota use on mine.
    -Chap
  7. Elektroingenieur
    2,515
    3,288
    Three Touring
    Get Neji-saurus (screw removal pliers from Engineer Inc.) on the job.
    pilotgrrl, RRxing and Prodigyplace like this.
  8. BZzap!
    1,607
    878
    If you look closely, the crown of the screw head is tapered to prevent any clamping, i. e. Pliers. I got to say, “This is some effective security screw.”. I think this is going to require cutting a slot in the screw head with a small abrasive wheel such as a Dremel. I’ve Googled just about every type of security screw that’s out there and came up empty. These screw probably came in a kit along with a matching key and are apparently very proprietary.
    http://www.instructables.com/id/How-to-open-security-screws/?amp_page=true
    #8 BZzap!, Nov 11, 2017
    Montgomery and BasemS like this.
  9. RRxing
    2,562
    1,840
    NEPA
    It looks like a pair of fine point needle-nose pliers could be inserted in the gaps, then twist and shout!
    Montgomery likes this.
  10. ChapmanF
    18,982
    I have definitely Dremeled slots into heads of things I needed to unscrew before; it's a time-honored, effective technique. :)
    -Chap
  11. BasemS
    Auckland
    Finally...i did it.
    I managed to unscrew the stereo from the frame holder without touching this security nut/screw head.
    It was very time consuming but luckily it worked.
    Thanks for the advices .... much appreciated.
  12. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    Hi , I have exactly the same problem and could not find any solution for that , could you please tell me how to unscrew the unit and what kind of tool you used ?
  13. A Tinkerer
    A Tinkerer New Member
    New Zealand
    2012 Aqua
    I don't actually own a Prius, but have the same problem with a different 2014 Toyota. I know my reply is a bit late, but I have a last resort idea which I haven't tried myself - if there is enough space, use a cordless multi-tool to cut a slot into the screw head, then unscrew it with a flat-head screwdriver.
    In my case, it may just reach or it could be 1cm too short. Just an idea, it may be a bit messy. Try at your own risk.
  14. ChapmanF
    18,982
    An old-fashioned rotary tool (like the iconic Dremel) with a small cutoff wheel probably requires less working space than one of those oscillating tools.
    Of course now Dremel sells oscillating tools too (as does pretty much everyone else, now that Fein's patent has run its course).
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Put your left foot in and your right foot out, then your your left foot in and turn it all about..........................
  16. ChapmanF
    18,982
    Left foot's already in. Remind me not to let you choreograph.
