Stereo watts
Discussion in 'Gen 3 Prius Audio and Electronics' started by JSL1, Dec 3, 2011.
  1. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Sadly I am in agreement there! It's too bad some manufacturers come up with their own standards, and how many suckers spend their bucks for this item. When it blows up. they wonder why. I see this stuff all the time, you are right, Caveat Emptor!
  2. JDBreaux
    JDBreaux Junior Member
    Bayou Vista, Louisiana
    A sticker is good for 12 db and certifies the Amp as Creme Relator Axiom Prefectius or C.R.A.P for short. Very prestigious
  3. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    The JBL GreenEdge in the Prius Plug-in only makes this cryptic statement ""8-channel high-voltage DSP amplifier, 120 Green Edge Watts = 600 Equivalent Watts" Not much useable information.
  4. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    I've found that the better amplifier manufacturers:
    A) Underrate their amplifier wattage.
    B) Bench test each amplifier and provide a certificate showing what the amplifier actually produced.
    Speakers are rated by efficiency. A more efficient speaker will produce more SPL than a less efficient speaker from the same RMS wattage, ALL OTHER THINGS BEING EQUAL.
    A sealed subwoofer enclosure will require a LOT more wattage (double?) to get the same SPL as a ported or bandpass enclosure, but will have much tighter bass response.
    That $65 1000W amplifier <might> produce 1000 watts <ONCE> if struck by lightning.
