Stiff gas pedal / new '09
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lamusic, Dec 16, 2008.
  1. lamusic
    lamusic New Member
    I just bought an '09 Prius but for some reason the gas pedal is very stiff. I think the alignment may also not be right because when I drive the car it tends to pull a bit to the left or the right.
    Has anyone else had this problem?
    I test drove the same Prius at another dealer before I bought this one and it was fine - I wonder what is up?
    I test drove the car I bought today in the rain...and I thought it was just the car reacting to the rain (the stiff gas pedal) - the salesguy said it was the vehicle stability control acting this way in the rain....but now it's not raining and the gas pedal is still stiff.
    Help!
    Should I take the car back?
  2. effwitt
    effwitt Paparazzi Magnet
    225
    Eagan, MN
    Stiff gas pedal: It's easy to prove that it's not the stability control - press the gas pedal with the car off and see how hard it is to press down. If it were mine, I'd get a flashlight and look at the pedal while a press down with my free hand. You might see something silly causing the pedal to stick.
    Alignment: Make sure that the tires are properly inflated to the recommended pressure and in an empty parking lot, take your hands off the steering wheel driving at a moderate pace. If it pulls to one side, take it in to the dealer for an alignment. It's wouldn't be the first Prius to have an alignment problem.
    (and welcome to PriusChat!)
  3. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Alignment issues on a new car are common. Nobody knows exactly why but Toyota is offering a free alignment to put it back in spec. When I bought mine, I test drove 3 - the first two pulled to the left. The third was fine and that is the one I purchased.
    Regarding the pedal.. it is much stiffer than most cars. Likely your pedal is fine. I will tell you this: when I get in my wife's Mazda (zoom-zoom) I go zooooomm-zooooomm because her pedal is much softer and I'm not used to it.
    Go talk to your dealer about the alignment.. you should get it fixed without cost or incident.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    AFAIK, everyone knows exactly why...it's standard for all Toyota vehicles. There's a 12month/12k mile "adjustment period" where they will fix your alignment if there are MPG or pulling issues. They'll also make changes with the scan tool upon request during that period for free.
  5. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    The alignment warranty on my 2007 is for 12 months/20,000 miles.
    I think it's the same on the 2008 & 2009's as well. Check your Warranty Booklet. There should be a separate sentence stating the limits of the alignment warranty.
  6. richard schumacher
    7,663
    1,038
    United States
    I'd bet a nickel that the floor mat has come free from the restraining hooks and is bunched up under the gas pedal.
  7. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    With regards to alignment, all of the new vehicles (Nissan, Honda, Toyota's) I've owned in the past two decades would give a free alignment in the first year/12,000 miles if I requested it, and I have needed alignment on all of them within the first few weeks...except the Prius so far. (However, I will request alignment on the Prius before the time is up.)
    Factory alignment appears to be approximate from all mainstream manufacturers, either that or it tends to get knocked out during loading, shipping, somebody's test drive, etc.
    So, no, I don't believe this has anything to do with the Prius in particular. If the vehicle pulls or handles strangely when new, insist on the free alignment and make sure they give you the printout.
  8. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    And also depends on the road you normally drive. For example, I notice my Prius pull to the Left more when I drive to work on a Hwy, according to the shop, it is because the road surface is curved so water can drain to center ditch. Which somewhat make senses.
    But lately I notice the pull seems to be more, even I am driving on a somewhat flat surface. So I check my tire pressure, and as expected, the driver side pressure is lower than passenger side.. I just filled up, and will see how it goes for the next few days.
  9. lamusic
    lamusic New Member
    So I took the car back to the dealer - I think the gas pedal is just stiffer than I'm used to because I test drove the same car and it was the same.
    They said they checked the alignment and it was fine.
    I guess the way the new car drives just takes some getting used to.
    Thanks for all the advice guys!
    The best part of the car (besides the fact that it's a Prius) is the smart key - amazing!!! I just keep it in my purse. Very cool!
  10. Patrick Wong
    18,200
    6,464
    Glad you are getting used to your new car. Please note that the accelerator pedal assembly is spring-loaded. The level of tension you feel in the pedal will not change based upon driving conditions (this is not like a fancy video game that provides feedback to the controller.)
    Yes, the Smart Entry/Smart Start feature is great.
  11. lamusic
    lamusic New Member
    The only other thing I've noticed is that the engine is a bit louder than the other Prius I drove.
    Has anyone else noticed this?
    When I rented a Prius a few months back it didn't seem like the engine was as loud...
  12. Patrick Wong
    18,200
    6,464
    We haven't driven your car so we can't say if it is noisier than other Prius. However I would agree that the Prius in general can be quite noisy under full acceleration; I think this is deliberate to encourage the driver to drive conservatively (and thus improve realized mpg.)
