Stiff Steering
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KeJa16, Dec 28, 2016.
  1. KeJa16
    KeJa16 New Member
    Buffalo, NY
    I recently took my 2011 Prius in for an oil change and an alignment. When I got it back, the steering is now really tight (harder to turn) and my mileage dropped. I took it back and they said there was computer issues. (I had it at a local garage). Their computers would not clear the codes so they towed it to a nearby toyota dealership. I was told that they ran diagnostics on it and a fuse burnt out. They replaced the fuse and reset the computer system. It still feels tight to me and was wondering if anyone else has had this issue before.
  2. fuzzy1
    10,171
    If a fuse burned out, does that mean the Power Steering Assist was no longer functioning, so you were back to old-fashioned manual steering?
  3. KeJa16
    KeJa16 New Member
    Buffalo, NY
    It sounds like the fuse blew after I took the car back and they were trying to troubleshoot the issue. The dealership diagnosed the fuse and replaced it.
    #3 KeJa16, Dec 28, 2016
  4. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    You have to find the fuse and check for yourself.
    Here is the post that mentions there is a fuse that causes it to become almost manual steering when you remove it or it's blown.
    Steering "Feel" And That Beautiful Yellow #25 Fuse
    He tells how he removed the fuse and the steering went very manual.
  5. KeJa16
    KeJa16 New Member
    Buffalo, NY
    Ok. The dealership fixed the fuse and reset the system. I would hope they sent me home with that all taken care of, at least
  6. KeJa16
    KeJa16 New Member
    Buffalo, NY
    Just went under the hood and noticed that both coolant tanks were low. Would this affect the steering?
  7. bisco
    49,500
    welcome!
    could the oil change company have accidentally let fluid out of the power steering system? i think it's electric.
  8. KeJa16
    KeJa16 New Member
    Buffalo, NY
    I had that thought so we checked under the hood which is when I realized the prius does not have a power steering reservoir to fill!
    Raytheeagle and bisco like this.
  9. bisco
    49,500
    something funky happened though.(n) you'd be surprised how many threads there are about going in for routine service, and coming out with a problem you've never had before.
  10. ChapmanF
    15,649
    Electric it is. No fluid involved.
    -Chap
    pshawfocus and Raytheeagle like this.
  11. bisco
    49,500
    could be a tough problem to solve. did they let the air out of your tyres?
