Still Misfiring After Cleaning IM - Please read
Discussion in 'Gen 3 Prius Technical Discussion' started by dirt657, Dec 1, 2018.
  1. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    And maybe a compression test so you know which cylinder is most worth scoping: Compression Test | PriusChat
  2. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Well boys, I took a look at it. Headgasket is done. Time to get to work :cool:
    Ordered a head and a gasket from Ebay.
    amos, PriusCamper, SFO and 1 other person like this.
  3. PriusCamper
    13,465
    5,431
    Sure wish we could better understand why in the heck ruined Prius longevity by redesigning the EGR system and blowing up the engines early? How come Gen2 Prius never have this problem?
  4. PriusCamper
    13,465
    5,431
    If you can document the repair work and share it, that would help others in this situation....
    amos and SFO like this.
  5. Mendel Leisk
    42,347
    Second gen doesn't have EGR?
    amos, m.wynn and Raytheeagle like this.
  6. PriusCamper
    13,465
    5,431
    It's an interesting question in that the Exhaust Gas Recirculation (EGR) is way different on a Gen2 Prius compared to a Gen3... And if you do some googling it seems as though parts for Gen2 EGR system are hard to find, barely even exist, but there's a flood of them for this major defect in Gen3.
    Thinking I need to do a new post about this to get more info... There's a solenoid in Gen2 EGR valve system and the pipe seems to have more capacity. Also the Gen3 EGR Valve assembly has a cooling system with a smaller pipe. But I've not worked on 'em so I'm just Googling, which too often gives you the most popular answer not the right answer.
    Perhaps the addition of the cooling system design is what ultimately led to destroying Gen3 engines prematurely?
    #26 PriusCamper, Dec 11, 2018
    Greenteapri likes this.
  7. PriusCamper
    13,465
    5,431
    Just found that @Tideland Prius mentions in this 2009 post about differences between Gen2 and Gen 3:
    "Exhaust Gas Recirculation System (recycles cooled exhaust to lower the engine temperature. It saves fuel because normally, fuel would be used to cool the cylinders)" Differences between Gen II and Gen III??? | PriusChat
    So now that the Gen3 are getting closer to a decade on the road, it seems that this "improvement" was an epic fail in terms of engine lifespan, unless you add an oil catch can and do regular cleaning.
    I wonder if Gen4 and later model Gen3 made changes to solve this problem?
    amos and Greenteapri like this.
  8. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Gen 3 EGR remained unchanged through 2015. I put a 2015 valve and cooler on my 2010, and they were identical to the naked eye. Gen 4 moved the EGR cooler downstream of the cat, presumably to try and further clean up exhaust gas before it enters the EGR path. It's still external, cooled EGR from the same playbook as turg gen, tho. Time will tell, but I'm betting (hoping;)) it will prove to at least be an improvement.
  9. Tideland Prius
    16,680
    Someone mentioned that it was. @Rmay635703 or @Mendel Leisk ?
    Non-Hybrids are starting to use EGR too. I can’t remember off the top of my head but I remember reading an article or press material recently and was caught off guard by the mention of an EGR.
  10. PriusCamper
    13,465
    5,431
    Pretty sure origins of EGR were related to strict California vehicle emissions requirements that got us out of the smog alert days of the 70's and early 80's. As far as I know EGR has been a standard emission requirement on all gasoline vehicles for a long time, and not just in California. If I'm incorrect I hope someone says something!
  11. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    My '07 Mazdaspeed 6 has an egr. It had a tendency to clog and throw a CEL. We just block it off and delete it.
  12. padroo
    padroo Senior Member
    2,763
    2,253
    The first car I had with an EGR valve was my 1977 Cougar XR7. The first car I remember with a catalytic converter was a Chrysler about 1975 and they used what was called the "Lean Burn" but those were carbureted cars.
    m.wynn and PriusCamper like this.
  13. Tideland Prius
    16,680
    Ohh? Did not know that. Maybe I was thinking Exhaust Heat Recirculation System?
    Either way, I haven’t heard of these until the Gen 3 Prius was launched in Detroit in 2009. But then again, I never really looked into emissions requirement prior to 2009.
  14. m.wynn
    684
    1,230
    Queensbury, NY
    Gen 2 EGR parts really don't exist:). The ecu controls VVT to allow back flow of exhaust gas into the intake at typical EGR indicated engine loads. Slick and maintenance free but the cooled, external set-up (gen 3 and 4) allows for higher thermal efficiency in the hunt for higher mpg's.
    VVT solenoid;):confused:?.. And what "pipe" are you referring to?:confused::confused:
    #34 m.wynn, Dec 11, 2018
    Robert Holt, PriusCamper, SFO and 2 others like this.
  15. Mendel Leisk
    42,347
    I don't think second gen has EGR. The term Exhaust Gas Recirculation does appear in the Repair Manual acronym list, opposite EGR, but that's the only place it appears. Looking at the exhaust manifold and exhaust pics, there doesn't appear to be anything branching off:
    #35 Mendel Leisk, Dec 11, 2018
  16. PriusCamper
    13,465
    5,431
    Thanks for helping us understand @Mendel Leisk and @m.wynn
    I was simply using Google image search and Ebay search, as well as looking at old articles online to figure it out and the pipe and solenoid were descriptions on Ebay when searching for EGR stuff for Gen2 Prius, which may not be that accurate...
    When you're saying VVT you mean Variable Valve Timing, right? So essentially it's recirculating exhaust gas by keeping the exhaust valves slightly open on the intake stroke. That's pretty clever... A great way to simplify the system...
    Mendel Leisk and Raytheeagle like this.
  17. padroo
    2,763
    2,253
    Im pretty sure VVT was meant to improve performance and Honda comes to mind. A lot of performance seems to trickle down from racing.
  18. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Wikipedia lists the 1nz-fxe as having VVT-i. That's one VVT on the intake side. Wouldn't you need a dual VVT-i for EGR?
    m.wynn likes this.
  19. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Can anyone else redirect me to a guide to pull the engine? I’m also wondering if it’s going to be easier to just replace the head in the car rather than pull the engine. I’m gonna start on this most likely tomorrow or maybe today.
  20. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Also is that video of the dude swapping an engine into a 2012 Prius V the same as my 2010?
