Stolen catalytic converter in london uk
Discussion in 'Newbie Forum' started by Priusinlondon, Aug 24, 2018.
  1. Nozzavtr
    Nozzavtr Member
    62
    62
    United Kingdom
    I'm hoping you're right about them not attacking the car again, especially as I've got an OEM Cat now fitted, not my choice, but the insurance company insisted. I'm going out today but am leaving the car parked up tight against a wall, so it can't be jacked up, and thankfully I have cctv so will be keeping an eye on the car at various points. Annoying but I shouldn't have to. I haven't got around yet to fitting the extra security but when I make a start I will take lots of pictures, as the kids are off on holiday I've had to keep them entertained instead!
  2. Data Daedalus
    Data Daedalus Senior Member
    763
    779
    Wembley, London
    Please remind me; does your replacement OEM CAT now have physical protection? Was it you who just had a CATLOC fitted?
    If so, then you have a fighting chance you’ll be fine. If it’s just etched and nothing else.....they’ll likely be on to it like flies on a rotten fruit .
    I sincerely hope you’re not hit again. Ever
    iPhone 6s +
    Nozzavtr and Mark6868 like this.
  3. Nozzavtr
    Nozzavtr Member
    62
    62
    United Kingdom
    It does, the Catloc is fitted. It rattles a treat underneath the car thanks to the chain attached to the chassis but it's fitted. May cable tie the links together to try and minimise the noise, well, when the weather warms up!
    Data Daedalus likes this.
  4. Nozzavtr
    Nozzavtr Member
    62
    62
    United Kingdom
    If you zoom in you can see the bolts and the steel cage around the cat
  5. Devdas
    Devdas Member
    102
    114
    London
    ----UK----
    the prius has two catalytic convertors
    Does this cage go round both the cats or just the one cos the Prius has two these crooks are getting two for the price of one
    They steal both in some cases as seen in the photo
    Question is does the cat lock protect both or just the one please
  6. Nozzavtr
    Nozzavtr Member
    62
    62
    United Kingdom
    Basically there’s another lock around the other cat, the kit comes with two locks so both are protected. I had a look through the back of the engine and saw the clamp and the green chain cover there so both are protected.
    Bobo Gem, Devdas and Data Daedalus like this.
  7. Devdas
    Devdas Member
    102
    114
    London
    ----UK----
    Sadly the gen 3 is also now a target hopefully it’s a one off.
    They caused damage to the car didn’t manage to take the catalytic convertor off but poor bloke is going to be out of pocket.
    Mark6868 and Data Daedalus like this.
  8. Data Daedalus
    763
    779
    Wembley, London
    Good heavens! That’s horrendous damage right there!
    This is beginning to look like the work of either (our theoretically dreaded) UK home grown copycat wannabes who’ve heard that there’s a juicy ‘platinum / palladium mine’ under every Prius....
    Or it’s one of the syndicate’s latest illiterate hired helpers who cannot tell the difference between a Gen 2 and a Gen 3 Prius - and got confused.
    Either way, this sets a bad precedent.
    Can anyone confirm the Gen 3 catalytic converter is relatively worthless to these thieves due to it having been redesigned with a precious metal coated (as in plated) ceramic matrix core?
    If so, whoever embarked on this theft is a catatonic dunce who didn’t do his homework!
    I can see the Dumkopf cut through what looks suspiciously like a pressure pipe - is that a drop of brake fluid I see underneath the cut pipe?
    Nasty damage - the poor owner is indeed gonna be out of pocket
    How so very depressing!
    iPad ? Pro
    Mark6868 likes this.
  9. Devdas
    Devdas Member
    102
    114
    London
    ----UK----
    I maybe wrong but I think what happened with gen 2 Prius the metals used in the catalytic convertors were cheap at the time when they were manufactured but since then some of the metals are now worth more then gold.
    The new catalytic convertor has a coating of this precious metals on a ceramic honeycomb structure similarly to the after market catalytic convertors for gen 2.
    I am hoping this above incident is a case of mistaken identity that all Prius = precious metals.
    As for the damage done it seems horrendous not likely to be brake lines as they are quite slim. Either fuel or coolant as there is a inline filter if you look at the other side where the pipe is cut. These fools could have set the car on fire hopefully themselves too in the process.
    Data Daedalus and Mark6868 like this.
  10. Bobo Gem
    Bobo Gem New Member
    London
    I'm in Toyota, they've just told me that the Toyota cat lock can only fit OEM. They will not fit it to mine.
    @Nozzavtr your insurance fit a OEM and then Toyota fit the catlock right?
    Any ideas what I could do now? Help appreciated
  11. Nozzavtr
    Nozzavtr Member
    62
    62
    United Kingdom
    I didn’t realise it would only fit the OEM cat, my insurance did fit an OEM cat and then I had to pay for the Catloc out of my own pocket, Toyota fitted it. They never told me that it would only fit the standard cat. You could try getting a Catclamp instead, that’s like a steel wire cage that will fit around the new Cat, but you may have to get the top of the range one to stretch around both cats.
    #651 Nozzavtr, Apr 15, 2019 at 4:55 PM
  12. Mark6868
    Mark6868 Member
    77
    76
    London
    2001 Prius
    They never told me that it had to be an original CAT.
    They just laughed at me for having a Gen 1. Basically told me to get a life, and in doing so get a newer Toyota Prius.:(:(
  13. Data Daedalus
    763
    779
    Wembley, London
    A Toyota UK dealership laughed at you for having a 1st Gen Prius?!!
    Truly, the world has gone quite MAD...!!!
    iPhone 6s +
  14. Mark6868
    Mark6868 Member
    77
    76
    London
    2001 Prius
    They certainly did Data. :barefoot::(
    I guess I can name them now that I no longer have to deal with them. (y)
    Jemca Toyota, Edgware Road is where this dastardly deed occurred. I believe you're familiar with them! o_O
    I can also report from previous visits that they drive our cars without any due care. My dash-cam made for interesting viewing after my sacred Gen 1 was serviced by them. Road humps be damned. The 'Sitting Duck' was very nearly launched into space such was the speed they drove it over some speed humps. :(:(
  15. Bobo Gem
    Bobo Gem New Member
    London
    @Data Daedalus where did you get your non OEM cat secured and what method was used? Cost? Etc
    I need help to get my non OEM cat secured as toyota will not do it since it's non oem ☹️
    Thanks
    #655 Bobo Gem, Apr 16, 2019 at 2:36 AM
  16. Nozzavtr
    Nozzavtr Member
    62
    62
    United Kingdom
    Catalytic Converter Security | CatClamp
    You could try and get one from the site above, then just get a garage to fit it, but you'll probably need the Maxx one to cover both cats, or buy two economy ones.
    Data Daedalus and Bobo Gem like this.
  17. Mark6868
    Mark6868 Member
    77
    76
    London
    2001 Prius
    I don't think that company is running any more. They certainly were not a few months back when I phoned them. All I got was a hefty phone bill thanks to their premium phone number. No emails were ever read, let alone replied to.
  18. Nozzavtr
    Nozzavtr Member
    62
    62
    United Kingdom
    that's a shame, maybe you could see if they have a division in the USA at all? Might cost a bit to send over but might be an idea?
  19. Data Daedalus
    763
    779
    Wembley, London
    Hi Bobo Gem,
    I’m afraid I had my security solution custom constructed and installed for me by a member on here who took a day off work and kindly did the job for me - something I will forever appreciate!
    It was not cheap, but that’s irrelevant to me, as the kindness involved in constructing and installing it for me is genuinely priceless.
    Just for the record, he doesn’t do that for a living, but was simply one of the most talented and ingenious people I have ever met.
    Did I mention the kindness involved?
    However, all is not lost; I’ve just remembered that I’ve still got one CatStrap Security Protection System available at home.
    I’ve already sold one, but the other one (alarmed version) is still available for sale if you’re interested.
    I ordered 2 of them from the US out of pure desperation late last year, though I didn’t use them in the end, as a day after ordering, I made contact with my generous ‘custom build CAT protection’ friend, who literally did me proud.
    PM me if you’re interested in purchasing this solution.
    https://www.catstrap.net/
    iPad ? Pro
  20. Peter R Johnson
    Peter R Johnson New Member
    Tuesday
    London
    Active
    I'm thinking you might be right about guns. I'm an Australian (born 1952) living in London for a couple of years and just had the catalytic converter stolen from my 2008 Prius while parked in the street in Chelsea last week. To those who don't know, Chelsea is upmarket, but we are not. We only live here and pay the huge rent because my spouse is a critical care doctor and needs to be very close to her hospital. Until recently, I have been extremely opposed to civilians having access to guns. I don’t know anyone in Australia who even owns a gun (almost nobody does). But sometimes crime escalates to the point where one feels the need to be able to do something to help stop criminals acting with impunity. There are YouTube videos showing thieves casually stealing cat cons with no fear even under the view of large numbers of onlookers. They wear masks/balaclavas and it's obvious what they are doing but onlookers are afraid to do anything (with good reason because these miscreants have been proven to carry large knives/other weapons and prepared to use them). Responsible use of a gun by a responsible citizenry would give these miscreants to pause for thought. But with guns, it seems to have to be either liberal gun ownership or completely restricted. I think there can be no in between. Some countries have high gun possession/ownership, such as Switzerland, but have very little gun crime. I do wonder if open gun ownership would work in the UK? I suspect that the traditional British ethnic population before immigration may have presented little problem with open gun ownership, but now it's a different story.
    And while I'm in a writing mood, just a word about weapon laws being applied unwisely: not long after I first arrived in London in 2017, I went to the Museum of Natural History (South Kensington, London) - a place I have admired from afar and was excited about visiting for the first time. Entrance signs indicated that we needed to declare any items such as pockets knives etcetera, so I declared a multi-tool I had at the bottom of my rucksack. The (Eastern European) security chap to whom I happily and naively declared the presence of this tool (thinking I would lodge it with security and get it back on exiting the museum), asked me to 'just wait'. This tool, I was told, had a blade that was longer than allowed. I said that I just live down the road and that I'll quickly take it home and return if it's causing a problem. He said nothing. Deliberately as I since discovered. Very soon the security supervisor appeared and very rudely informed me that this is illegal in the UK (which I did not know) and that he was confiscating it. It was obvious that I was not a terrorist or troublemaker but when I complained that it was not his to confiscate, I was told by the supervisor that he will call the police if I continued to complain. At this time my benign mood and countenance quickly changed to one of displeasure and grimace. I considered just grabbing the item and if necessary, knocking over the supervisor while reclaiming my device and just exiting the museum - however I did not for other reasons (long story). This supervisor was a black man and the first security officer was Eastern European – I only say this because most of the crime in the UK is carried out by black males and Eastern Europeans. And so, I thought this to be ironic. For information, my son is black (OK, half black because I’m white). My (second) wife is Chinese. I am not xenophobic/racist/chauvinist/terrible person etcetera. During this interaction with the security people, the Eastern European chap said in a very loud accusative voice, “…this is not America (he thought I was American) or Australia or another country… this is Britain…” (I’m still unsure if he realised the irony of this). These security people set me up for the tool to be confiscated. I wrote to the Museum and my letter was forwarded to the Chief of Security. His reply was pathetic, writing something like: “we have to continue to fight terrorism…”. This private security company attitude to ‘security’ here is laughable. I still have the letter which I can forward to anyone interested.
    It looks like I’ve gone slightly off topic. Sorry.
Loading...
