Stolen Catalytic Converter - O2 Sensor Ripped - Which one is it?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Friendlyx, Sep 25, 2019.
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    I'm wondering which o2 sensor they ripped out? Is it the upstream or downstream? Also, how hard is it to replace? Thanks in advanced! [​IMG]
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Downstream. Upstream one is Air/fuel ratio sensor and is mounted in the exhaust manifold.
    The one you're looking for is this one (I've been disassembling my spare 2007 parts car). The electrical plug enters through the floor on the passenger side and attaches to the car harness near the center console.
    #2 TMR-JWAP, Sep 25, 2019
  3. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    How would i even get to the car harness? Where would i go in through?
  4. TMR-JWAP
    6,404
    6,099
    Columbia, SC
  5. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Nope 100% right, its about my 06, thank you!
  6. Cmitchelldog
    Cmitchelldog New Member
    Suisun City
    Hi my 2007 cat was stolen so I only need downstream 02 sensor to replace cat? I saw wires hanging down and bolts on ground when happened.
  7. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    This is correct. The downstream sensor is located between the two cat bodies near where the pipe bends. It's wires pass up through the passenger side floor board and run under the carpet along the passenger side of the center console, where it plugs into the car's wire harness.
    Those bolts are probably the mounting fasteners for where the exhaust pipe attaches to the exhaust manifold. Should be 2 bolts and 2 springs..
  8. eljefino
    eljefino Junior Member
    43
    25
    Maine
    If you wind up with a generic R02s you can splice the wires under-the-car and use the heat-shrink that comes with the part. Could be cheaper and easier.
    Give the sensor about three counter-clockwise twists before putting it in the new tailpipe-- it'll untwist itself as you thread it in and won't be a twisted mess when done.
