Stop light stupidity.
Discussion in 'Gen 2 Prius Technical Discussion' started by harryarcos, Oct 12, 2018.
  1. harryarcos
    harryarcos Junior Member
    81
    24
    London
    Shocked to discover that it was more than just a failed bulb when the stop light in the NS rear light cluster failed to light up. After drawing a blank looking at the fuses and wiring, I looked here to find that it is a sealed unit and the whole light cluster needs to be replaced at a cost of about £150. This is such a stupid design, as it means that the car is not road legal while the light is out. However, I have now managed to get 3 of the LEDs working by cutting off pieces of plastic behind the lights, removing the LEDs and rewiring them to just use the good ones. There is no fancy circuit and the LEDs are wired in a series of 3 so that each one draws about 4 volts. When they fail, they either go out or draw a lot more voltage making the others so dim that they cannot be seen.
    Mendel Leisk and bisco like this.
    52,785
    well done!(y)
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    What year gen 2’s have these led bulbs? The bulbs in my 2006 look like regular bulbs to me.
  4. harryarcos
    81
    24
    London
    This is a 2004 vehicle. I was not aware that the top sections which are black were actually stop lights. I jumped in by checking the bulbs etc. behind the red lower sections. Incidentally, the fuses for the stop light are beneath the steering wheel and really difficult to service. They are numbered wrongly in my handbook, which did not help and Haynes was about as much use as that 'chocolate fireguard'. IMG_9845.JPG IMG_9847.JPG
  5. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Wait untill you find your automatic headlight position'er failing and look at it, they rust and you need a spring from a ballpoint pen to "fix" the device;)
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    For automatic headlight leveler you can also simply use a potentiometer. Did it with one of my personal cars.
    JasWalker and SFO like this.
  7. bisco
    52,785
    u/k may have different lights
