Stop light switch
Discussion in 'Gen 2 Prius Main Forum' started by GRNDHOG, Feb 22, 2013.
  1. GRNDHOG
    GRNDHOG Junior Member
    Can anyone give me any pointers to replace the stop lit switch aka brake light switch ?
    I can't even figure out a way to get a wrench in there to loosen the bolt.
    Thanks in advance!
  2. GRNDHOG
    Bump. Anyone?
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    According to the service manual, it looks like one is expected to remove the brake pedal assembly in order to get at the switch. That involves removing the instrument panel subassembly, then removing the spring and clevis that connects to the master cylinder, pulling the connectors, then removing the four bolts that hold the brake assembly.
    It might be that removing the instrument panel will allow enough access to get at it. There are dash board disassembly photos on PC, and youtube also I would guess. I've not been in there. Yet.
    GRNDHOG likes this.
  4. Patrick Wong
    18,200
    6,492
    I haven't needed to do this. Referring to the Toyota repair manual, it suggests you remove the lower instrument finish panel (first pull out the ventilation duct on the far left by grabbing it at top and bottom and exerting a horizontal pull.) Remove the wiring harness connector on the stop lamp switch. Then use a wrench on the stop lamp switch lock nut to loosen it. Rotate the switch to remove it from the bracket.
    When reinstalling the switch, the clearance is 0.5 - 2.4 mm. Tightening torque on the lock nut is 19 ft.-lb.
    [email protected] and GRNDHOG like this.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Take a look at this. It is for a gen 1 but it should help. Refer to the para. "Replacing the Stop Light Switch".
    Cruise Control
    GRNDHOG likes this.
  6. GRNDHOG
    Awesome! Thanks everyone!
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Why do you need to do this? Perhaps just get it by a dealer and file a claim later? See Toyota Economic Loss Settlement Website.
    From there:
  8. GRNDHOG
    What is that telling me?
    Did Toyota extend this under a recall of sorts?
    Or is this a class action that I pay for my own repair and hope I get something back? I see their top payout is $125. I think the dealership will charge much more to repair it.
  9. Priusfromevil
    Priusfromevil Junior Member
    65
    KC
    I just received the notice in the mail on this.
  10. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I'd put it that way. In the past, when Toyota has had recalls, class action settlements or limited service campaigns for items, they've had procedures to file for reimbursement.
  11. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    [email protected] likes this.
  12. tracy ing
    tracy ing Active Member
    384
    171
    wash dc
    i just did it, open end crows foot wrench and a ratchet
