Stopping HV charging from low SOC at idle
Discussion in 'Gen 2 Prius Main Forum' started by slimothy, Feb 27, 2014.
  1. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    Running a block heater and/ or a small space heater in the cabin would cut down on the time needed to get to stage 4 in cold climate.
  2. Huelo Point Lookout Maui
    Huelo Point Lookout Maui Junior Member
    Speaking of charging behavior, my 05 reads about 0-20 mpg for the first 1/2 mile going on flat road with almost no gas pedal and almost a fully charged battery. Is that normal as it bring my avg down when it should go up. thanks in advance.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    During the first minute or two the engine is burning fuel to warm up, and it will use this fuel whether you're stopped or moving.
    Traveling slowly along a flat road with the engine warming up, you're pretty much using a fixed rate of fuel. Under these conditions you're going to get low MPG, and the slower you go the lower it will be. If you're stopped but are still using fuel then you're getting zero MPG, that's just maths.
    There's really not a lot you can do about it, we all get low MPG in the first few minutes.
