Storage for sunglasses
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Sep 15, 2023.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,253
    942
    Found this neat little addition to keep my glasses in one place and it was under $20
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Where did you get it ?
    And where is it mounted......and how ??
    ukulelegeek likes this.
  3. AzusaPrius
    2,253
    942
    Right above your head, you know that handle you grab when you are scared.
  4. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Looking through eBay and it shows that you have to remove the rubber liner.
    Did you have to do that or were you able to install without doing so?
  5. AzusaPrius
    2,253
    942
    Nope not at all, just remove the handle and install the new case.
    ukulelegeek and Xterra72 like this.
  6. Mendel Leisk
    42,305
    Seems like a diminishing requirement though; there is one, below the map lights. And that passenger side grab handle is the missus' "oh shyt handle"...
    #6 Mendel Leisk, Sep 24, 2023
    ukulelegeek and xliderider like this.
  7. Xterra72
    1,437
    1,684
    Personally have no use for those handles. Useless.
    The one below the map lights is shallow. Also useless other than maybe holding small reading glasses.
  8. Xterra72
    1,437
    1,684
    Did you use the oem metal clips and oem caps to re-install the sunglass holder? Or did you have to use the hardware it came with?
  9. AzusaPrius
    2,253
    942
    Comes with its own hardware.
  10. Xterra72
    1,437
    1,684
    Oh okay. Guess oem hardware just works with the Toyota Venza.
  11. Xterra72
    1,437
    1,684
    Can you send me the link to the one you got ?
  12. AzusaPrius
    2,253
    942
  13. Xterra72
    1,437
    1,684
    Thank you. Greatly appreciated.
    I purchased this one ☝️ and I had to return it. Wasn’t working out for me:
  14. ukulelegeek
    ukulelegeek Active Member
    159
    112
    Ha ha ha ha!
  15. ukulelegeek
    159
    112
    I grab one really fast, when I see one of my wife's reckless driving stunts coming! I also grab mine while driving a long ways, to give my arm a different position. Sometimes it just feels good,
