Storing a 4th Generation Prius long-term
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Puruisi, Nov 23, 2016.
  1. Mendel Leisk
    42,343
    My sense is there's nothing, and nothing really needed, from gen 3 onward. I could be totally wrong too, lol.
    kithmo likes this.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    At what can dogs get their licence in Q'land?
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The problem is - it hasn't been tested. I understand nobody gets driver's licences till they're 17yo here, by which time most dogs sadly are ex-dogs. Those which are still alive are either deaf, blind, arthritic or suffering from dementia, so aren't fit to sit the test. :confused:
    pjm877, RCO and booke02 like this.
  4. Tideland Prius
    16,680
    There's a quick way to shut off the SKS on the Gen 4 (mostly for car washes but I guess storage works too). Here's the normal stuff
    Here's the new Gen 4 key battery saving function
    The 12V battery on the Gen 4 is normal sized now and is located under the hood so in theory, it should be a bit more robust than those in the Gen 2/3.
    Of course for peace of mind, you can always use a battery tender.
    RCO and kithmo like this.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Call me an idiot, but even if the fob is isolated or shut down, is it not the car's own battery powered radio link that is searching for a suitable fob to pair with? I mean even a receiver that is not actually receiving a signal must use some power!
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    you're right in that it uses some power but the car's radio link is basically just antennas and goes into sleep mode a short period of time after switching off and locking the car, providing the key is not in proximity of the car, so uses very little power.
    IIRC, the car doesn't search for keys as such, the key actually searches for the car and the car is activated when one of the antennas picks up a signal. If the key is left within range of the car's antennas then the car will come out of sleep mode and be using more power, so leaving the key within range prevents the car going into sleep mode and uses more power.
    RCO likes this.
  7. Prodigyplace
    12,712
    11,848
    Central Virginia
    You are correct.
    According to the manual, you can turn off the smart key system using a menu on the middle display. I recently looked and could not find where it is hidden.
    Some older generation Prius had a physical button to turn off the smart key. A common problem was somebody accidentally hitting the button, disabling smart key functions.
    RCO likes this.
