Storing charging cable in the tight slot
Discussion in 'Prime Plug-in Charging' started by yoyoman, Dec 9, 2016.
  1. bisco
    52,863
    that second video should give yoyoman all the help he needs.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    @yoyoman from your descriptions of the cable it seems you may have not received the correct cable for the Prime. Can you post a picture of it?
  3. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    The 2nd video in split second already showing me how to. I think it will work and I just have to learn it. And the cable i have is correct with the blue plug and a bulky transformer/controller.
    Thanks everyone.
    iPhone ?
    52,863
    pleasure.
  5. arwalt86
    arwalt86 New Member
    US
    That's how a lot of cars are coming off the line now a days. I believe all the OEMs are starting to use run flats so you can at least make the temporary fix and then but a new $200 tire!
  6. yoyoman
    342
    117
    San Jose California
    Really? Maybe I did not finish the manual yet. Is it true that all prime is installed with run-flat tire?
    iPhone ?
  7. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    No
  8. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    AAA + full size or compact spare is a necessity.
    I have already had a flat and was thankful that I insisted on a model with a real spare tire. I had to drive 150 miles to get home, and had the tire fixed the next day when shops were open.
  9. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The number of flat tires I've had on tires that were properly maintained in 31 years of driving is ZERO. I've had several that got slow leaks due to punctures and had to be repaired, but all of those would go at least a week before losing enough pressure that I couldn't drive on them.
  10. William Redoubt
    1,228
    1,174
    Punctures are related to surface debris, not proper maintenance. Obviously you are an outlier. On the far other side of the average is a guy with a lot of flats.
    bisco and Mendel Leisk like this.
  11. Lee Jay
    5,850
    4,036
    Right. The only actual flats I've had were from improper maintenance. One was from a Ford Explorer that became unalignable and while the various dealers were trying to figure out the problem, it wore out the inside of the tire right through to the belts. I couldn't see it without being under the car.
    I asked around a little with family and friends, and most of them have had the same experience as I have - a few slow leaks but few or no sudden flats.
    I'm going to go with a compact compressor and a plug kit, and get rid of the goo and compressor Toyota provides.
    William Redoubt likes this.
  12. Mendel Leisk
    42,355
    Just luck. And maybe a lack of construction debris along your routes. I've had slow-leak and fast-deflating punctures. I'm mindful of tire pressures, and replace tires well before minimum tread depth.
  13. trescenzi
    trescenzi Junior Member
    29
    42
    CT
    To meander back on topic here's how I stored my cable plus a 15' 14gauge extension cord. They both fit in there just fine. It's a little tight but with some practice it should fit a lot better. IMG_2328.JPG
    iPhone ?
  14. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    The cord for our SAE J1772 charge cable has four conductors, two for power and two for communications between the car's charger and the control box that regulates power flow. The fifth pin in the plug is for proximity detection; it tells the car that plug is all the way in.
    Slime brand tire sealant is not what Toyota gives us. Thank goodness. There are other tire sealants that do a good job without Slime's mess. Ride-On is one that I'm considering putting into the tires as a preventive measure.
  15. Mendel Leisk
    42,355
    You're thinking to put sealant into all the tires, without punctures? Cargo cult.
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    That's not entirely accurate.
    The lower pin is ground pin, the two (small) above it are proximity pilot and control (communication) pilot.
  17. William Redoubt
    1,228
    1,174
    I think this is a good strategy, with the proviso that an AAA card is included for the flats that can't be plugged. On at least one flat tire I found a piece of metal about the size of a dinner fork sticking out of the sidewall. No plugging that one.
    A plug kit might also be useful for male pattern baldness. I am not real sure, however, since I have a full head of hair. I think (again, not totally sure) that used Mobil 1 oil restores a receding hairline. If you have had experience with either of these treatments, please chime in (runs fingers through hair, winks at sexy blonde at the next table and silently smirks at all of the pitiful shaved heads nearby).
  18. Lee Jay
    5,850
    4,036
    No, but I have roadside assistance on my insurance.
    You might actually be able to. I saw someone use about 10 plugs on one large gash, and he said it held for over 600 miles.
    Sorry, still have a full head of hair myself.
  19. bisco
    52,863
    please stop bragging you two.:mad:
    William Redoubt and Mendel Leisk like this.
  20. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I found the lug nut wrench in a vinyl bag in this compartment. Is that where it's supposed to be or under the rear seat where the jack is?
