Straight pipe with a tip
Discussion in 'Prius c Accessories and Modifications' started by papafern, Aug 26, 2018.
  1. papafern
    papafern Junior Member
    62
    NYC
    2015 Prius c
    I went to a hood muffler shop today just to look and ask about putting an exhaust on my Prius C. I had read that the Fiat 500 abarth doesn't have a muffler. It sounds good and not too loud because the engine is so small. So I asked the mechanic if it's possible to do this on the Prius and he said yes. While I was there's they were doing just that to a BMW X5 and to an Accord. What problems can it cause on the car??? Will it still work properly??? Any warning lights gonna go off??? What could go wrong???
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Do you have mandatory emissions or safety inspections where you live ??
    If so, that might end up being a costly mistake.
    And the Prius has an engine that is a bit different.
    I've only seen a couple with modified exhausts and both sounded like a sick lawn mower.
    #2 sam spade 2, Aug 26, 2018
    Starship16 likes this.
  3. Mendel Leisk
    42,201
    Aren't you supposed to give up on stuff like this once you're out of your twenties? ;)
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Pro
    1) It will be louder and annoy your neighbors.
    Con
    1) Fuel Economy will suffer
    2) Power will suffer
    3) The noise will be really inconsistent as the engine turns off frequently.
    4) Putting it all back to pass inspection will be expensive. Really expensive if you don't keep all the stock parts. (you can't certify an aftermarket Cat in NYS.
  5. papafern
    62
    NYC
    2015 Prius c
    Lol. Nah, u only get old when u stop doing young people things
    olftboy, ztanos and Mendel Leisk like this.
  6. papafern
    62
    NYC
    2015 Prius c
    How come fuel economy will suffer???
    Florida plates, no inspection. And if I needed a NYS inspection, I know people, lol. I also ride scooters. I look like a circus bear on it. So I like doing ridiculous things. I'm worried about making the engine less reliable or things not working right because of this.
  7. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    LOL!!!! :ROFLMAO: :D
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    This is not an Otto cycle engine. The compression ratio is about 8 to 1, while the expansion ratio is about 13 to 1, so little more expansion happens outside the cylinder. So a straight pipe is just about noise.
    A straight pipe will have no oxygen sensors, so the electronics will have no way to tune engine for perfect fuel to air ratio. (called closed loop) The electronics will used a preprogammed table to guess the perfect fuel air ratio and so reduce both economy and performance. (Open loop, in worst case called Limp Home mode)
    Open/Closed Loop Operation
    (This page is going to use Tuned Port Injection as TPI with defining it)
  9. papafern
    62
    NYC
    2015 Prius c
    The oxygen sensors are in the muffler??? What I saw the guys are the shop doing is cutting the pipe right before the muffler, then welding in a piece that is the about same length as the muffler was and welding a tip on it.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  11. papafern
    62
    NYC
    2015 Prius c
    Yeah, a muffler delete. The Fiat 500 Abarth comes from the factory without a muffler. It still has all the emission hardware. That's how I had the idea. I read that the engine is so small on the Abarth so it doesn't make too much noise and get a pass from the governmemt without a muffler. I was thinking that the C wouldn't be too loud because of the same reason. I'm worried that it will have negative effects on the engine because it's not an Otto cycle engine so it's different.
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you are leaving the pollution controls in place, getting keyed by angry neighbors is your main worry.
    Pro loud exhaust
    Con loud exhaust
    Sezy likes this.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I would think the exhaust note would just sound weird on a CVT drivetrain as the drone would be even more pronounced.
  14. Mendel Leisk
    42,201
    Ok, I haven't trotted this out in a while:
    ztanos likes this.
  15. papafern
    62
    NYC
    2015 Prius c
    I ride scooters and I'm used to what a CVT sounds like. I think it's gonna be weird is the on and off when going from electric to combustion. It's gonna make it easier to stay in electric mode on local streets
  16. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    How would this work on a Prius that doesn't have an alternator?
  17. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    NM... just googled it and found they have a free app that works through the OBD2 adapter I already have. :D
    SoundRacer Android app
  18. milkman44
    milkman44 Active Member
    591
    386
    Ky
    But, but, but, Loud pipes save lives don't you know?
  19. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Only on motorcycles... or so the theory goes. :rolleyes:
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    So tried this last night.. the free version does not include OBD2 functionality. Found the paid version online and tried it... apparently it doesn't like most OBD2 adapters and could not find mine either. From the reviews online, this app is not well applauded and I'm glad I didn't spend money on it.
