STRANDED (again) HELP
Discussion in 'Gen 2 Prius Technical Discussion' started by #1 Toyota salesman, Jul 19, 2018.
  1. #1 Toyota salesman
    110
    71
    GSP, SC
    I let someone borrow my car a few days ago, and they said it left them stranded, with the parking brake error. She was able to get the 12v reset and be on her way .
    Unfortunately obviously I couldn't pull the codes, if any.
    No I just got out of the junkyard, to replace my blower motor fan that went out yesterday. Replaced in the parking lot, went to get in the car, and I can't move.
    It won't ready, it won't turn completely off
    The 2 year old TOYOTA 12v battery checks out fine BTW
    I have unplugged both batteries, to no avail. The only code that is coming up in the reader is P0300 , using Dr Prius
    I've got to get this thing moving!
  2. #1 Toyota salesman
    110
    71
    GSP, SC
    52,855
    that's the parking pawl on the tranny isn't it? i would still test the 12v before deeper diving, maybe she killed it.
  4. #1 Toyota salesman
    110
    71
    GSP, SC
    We just load tested it 2 weeks ago
    I have no way to test beyond the MFD.
    I'm trapped in a salvage yard parking lot.
  5. #1 Toyota salesman
    110
    71
    GSP, SC
    I'm thinking it's an actual issue with the pawl or interlock in general.
    If I move the lever into "neutral" it shows it on the display , but I can't move the car.
  6. #1 Toyota salesman
    110
    71
    GSP, SC
    What if I tried to "jump it" at least hook up another battery to it with some cables, so I know it was for sure getting 12+ volts
  7. bisco
    52,855
    no one there with jumper cables? or maybe you've blown a fuse.
  8. #1 Toyota salesman
    110
    71
    GSP, SC
  9. #1 Toyota salesman
    110
    71
    GSP, SC
    I just hooked up another battery also, and it was reading 12.9 V with both batteries. No change - still park lock mechanism.
    Where is the park motor located? How hard is it to fix or bypass? Am I stuck/stranded?
  10. #1 Toyota salesman
    110
    71
    GSP, SC
    With the car in neutral, it won't move...as though PARK were engaged
  11. bisco
    52,855
    somewhere on the side of the tranny, but i have heard that access while it is in the car is difficult.
    have you checked all the fuses? the dome fuse prohibits starting.
  12. #1 Toyota salesman
    110
    71
    GSP, SC
    I said, I'm kinda stranded right now, and I have to work in a few hours.
  13. #1 Toyota salesman
    110
    71
    GSP, SC
  14. #1 Toyota salesman
    110
    71
    GSP, SC
    Looks like it's on the top back side? Remove the inverter?
  15. #1 Toyota salesman
    110
    71
    GSP, SC
  16. #1 Toyota salesman
    110
    71
    GSP, SC
    I love sleep deprivation. Guess what I didn't plug back in and reattach, after replacing the blower motor? And guess what my friend was beating up on the other day to get the blower to work? If you guessed "transmission control module "you win , and I'm a moron.
  17. bisco
    52,855
    congrats!(y)
  18. #1 Toyota salesman
    110
    71
    GSP, SC
  19. #1 Toyota salesman
    110
    71
    GSP, SC
    I just took a step back, calm down, retraced everything that happened
    SFO likes this.
  20. wanderso
    wanderso Junior Member
    Portland
    Great work! I had a friend text me this evening saying that they couldn't get their '06 Toyota pickup started. Plenty of battery with the starter cranking the engine just fine. I started asking questions and uncovered that he just had keys made at Home Depot. Drum roll... the duplicate keys didn't have the immobilizer chip. Of course it was cranking over but not starting... :) He was happy when it turned out to be so easy to fix.
    SFO likes this.
