Strange Braking Sound Persists after Brakes Fixed
Discussion in 'Gen 3 Prius Technical Discussion' started by Jerry Bleecker, Jul 1, 2019.
  1. Jerry Bleecker
    Jerry Bleecker New Member
    BC, Canada
    Technology
    Hello all. I’m new to PriusChat. I’m wondering if anyone has experienced a sound like this which seems to occur during low speed braking. I describe it as a metallic bump or shudder noise.
    I just had my rear brakes redone two months ago fully, and now the fronts, also totally. The bump sound persists even after. Trying to figure this one out.
    Any ideas greatly appreciated.
    52,819
    welcome!
    how long have you owned the car?
    who did the brake work?
    how many miles on her?
    Jerry Bleecker and Mendel Leisk like this.
  3. Jerry Bleecker
    BC, Canada
    Technology
    Hi
    My car is a 2010 with 106,000 miles. Toyota did the brake work.
    52,819
    have you owned it since new?
    what did the dealership think?
    Jerry Bleecker likes this.
  5. Mendel Leisk
    42,317
    May or may not be the issue, but one thing to check, if you can manage: chock the front wheels, release the parking brake, raise the rear till the tires are clear, then see how freely they spin. Should be something like this, if they didn't screw up the rear brakes.
    The rears are tricky, need to be reassembled with the pattern on the caliper piston face oriented like an "X", and well seated against the brake pads thus. If it does manage to rotate, you'll get a constant drag, bevelled pad wear and scored rotors.
  6. Jerry Bleecker
    BC, Canada
    Technology
    They were not sure at all. I have an audio file but being new to PriusChat I can’t share the DropBox link. I apparently need 4 posts...? It is a strange bump - a hollow sound that only happens with slow speed braking.
    Owned since new.
  7. Jerry Bleecker
    BC, Canada
    Technology
    Thanks for everyone’s input
  8. bisco
    52,819
    does it happen around 6mph when regen braking cuts out?
    Jerry Bleecker and CR94 like this.
  9. Jerry Bleecker
    BC, Canada
    Technology
    Yes, that would be about right. I have to log four posts, then I can post a link to the sound.
  10. bisco
    52,819
    could be the normal friction cut in
  11. Jerry Bleecker
    BC, Canada
    Technology
  12. Jerry Bleecker
    BC, Canada
    Technology
  13. Mendel Leisk
    42,317
    Can you pinpoint at what second the sound occurs?
  14. bisco
    52,819
    it seems to be seconds 6,7 and 8.
    Mendel Leisk and Jerry Bleecker like this.
  15. bisco
    52,819
    hey mendel, double posting from bc, canada
  16. bisco
    52,819
  17. bisco
    52,819
    reading your first post again, was the sound there before the rear brakes were redone, or after?
  18. ChapmanF
    19,001
    I've just listened and heard nothing out of the ordinary. But I didn't use headphones.
    I once did a little enhancement in Audacity for somebody's weird-sound recording, made it easier to pind down. But I'm not where I can conveniently do that just now. Maybe somebody else can?
  19. Jerry Bleecker
    BC, Canada
    Technology
    I had this sound before recently doing the front brakes. It developed about a month after the rears were done.
    In that service, they installed new pads, saved the existing calipers and machined the rotors.
  20. bisco
    52,819
    seems to pinpoint the rears, almost like something wasn't connected properly and came loose. i'm not an expert on what parts go in there and how they are connected.
    menders X alignment is important, but i would think the sound would have developed right away.
    maybe take it to another dealer and have them inspect it?
