Strange Braking Sound Persists after Brakes Fixed
Discussion in 'Gen 3 Prius Technical Discussion' started by Jerry Bleecker, Jul 1, 2019.
  1. bisco
    51,984
    are you recording from the drivers seat?
  2. Mendel Leisk
    41,497
    @Jerry Bleecker , further to @bisco's "X pattern", if you can: do try raising the rear and see how free spinning the wheels are. You can even do it one side at a time, with the scissor jack, in a pinch.
  3. Jerry Bleecker
    Jerry Bleecker New Member
    BC, Canada
    Technology
    Thanks for all your suggestions. I’ve been out of country for a bit before having the car serviced again. I took the car to the dealer. The rear brakes had loose pads and an odd exposed and somewhat sheared bolt they ground down...?
    Sound appears gone as I haven’t heard it in a week now
    Mendel Leisk and CR94 like this.
  4. Mendel Leisk
    41,497
    Did you see this? Any pictures, or more description?
  5. Joele3
    Joele3 Active Member
    135
    201
    Bay Area
    I remember when I lubed up the caliper pins on all the brakes. The rear brakes had these metal clips loose on the drivers side. I had minor clicking sound when braked at lower speeds. Once I lubed up the pins put the metal guides in correctly the noise went away. Laying on top of the pads. Got the screenshot from NutzandBolts youtube video.
    Raytheeagle likes this.
  6. ASRDogman
    ASRDogman Senior Member
    7,604
    3,915
    It's a good idea to either take photos or video of your work if you don't do this often.
    And only work on one side at a time. So you can look at the other side as reference.
    I'm happy you have everything up and running correctly!
    CR94 and Mendel Leisk like this.
  7. Mendel Leisk
    41,497
    Doubly so if working on drum brakes. (y)
    ASRDogman likes this.
