Strange Dorman Battery Voltage
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ikefor, Jan 13, 2016.
  1. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Ok, i got a friend whose Dorman battery recently failed. Well, he required some assistance with further understanding what the issue was as well as determine how to go about his warranty.
    I decided to use my Techstream to pull some codes from the car's ECU but noticed some interesting voltages from inspecting the battery itself.
    Voltages below were taken without the service plug inserted
    1. Positive and negative terminal - 138 volts
    2. Positive to battery ground - 40 Volts
    3. Negative to battery ground - 72 volts
    It appears that there is a short somewhere in the busbar/wireframe which explains why the Battery ECU is fried and wireframe connector to ECU has some voltages also.
    Unfortunately, to process his warranty, he has to pay a high shipping cost from/to Africa which makes little or no economic sense.
    I am encouraging him to order replacement OEM replacement parts, and do some module work on the pack instead but this will void his warranty.
    Has anyone noticed this kind of strange battery voltages?
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Wow. That does not look good.
    You will need to open it up more (thus voiding the warranty) to find out what else is wrong.
    Do you have your original battery pack?
    If so then you may be able to use parts from the original to fix this one, or vice versa.
  3. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    No my friend sold his old pack when the Dorman arrived about a year ago. There is no access to the gen 2 pri modules here but once can get access to TCH modules (the B2 and B4 modules). I have suggested that he make use of these modules in replacing any failed modules in his pack then do some module work.
    What i don't know for certain is if you can mix these modules together (pri and TCH) because of potential IR differences or does one just replace all the modules with the TCH modules then do some module work?
    #3 ikefor, Jan 14, 2016
