Strange front flapping noise.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Edmund, Dec 26, 2017.
  1. Edmund
    Edmund Junior Member
    Los Angeles
    2014 Prius c
    Hello and happy holidays!
    There has been this scraping squish sound coming from the front of the car. I noticed it's gotten a little louder these past months, but can't figure out what it is.
    At first I thought it was the tires. So I checked for debris and found none. The pressures are within range too.
    Anyone have any thoughts or opinions?
    Car has 29K miles and is 2014 model.
    Thank you!
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    All I can hear is the wind noise and a car horn... I do hear a slight clicking noise if that's what you mean.
  3. Edmund
    Los Angeles
    2014 Prius c
    Sorry about that. I'll try to get a better clip when I get off work. But yeah, it's that clicking noise.
    ztanos likes this.
  4. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    No worries, you do with what you've got, right? :D
    If it's the clicking noise, I would recommend that you listen as best you can to see which wheel it's coming from (general area, not saying it's a wheel causing it). Best and easiest way to do this is to drive as close to a wall as possible on both sides of the car to determine which side of the car it's on. Once that's established, you can have a friend ride with you and determine if it's front or back. At that point, you can eliminate the wheels/tires by rotating the fronts to the back and seeing if it moves with the tires/wheels.
    In my experience, this kind of clicking noise is usually a leaf or a rock or something in the tread, or in the rotor. Sometimes, however, it can be the CV axle... :(
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Wasn't there a user on here a few months ago that found a hubcap to be the culprit of a strange noise like this? Heck, might be worth a try at least. Wouldn't take more than a couple min to take them all off and go for a drive.
    bisco, ztanos and Raytheeagle like this.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Now that you mention it, I do recall this. He put it back on and the sound came back. Not sure how he resolved it.
  7. Edmund
    Los Angeles
    2014 Prius c
    Much appreciation for your replies, guys!
    It turned out it was indeed the fricken hub cab. I can't believe it.
    ztanos, dubit and Raytheeagle like this.
  8. bisco
    52,862
    good call dubit!(y)
    ztanos and dubit like this.
