Strange Handling
Discussion in 'Gen 2 Prius Technical Discussion' started by mary2al, May 5, 2008.
  1. mary2al
    mary2al Junior Member
    57
    SF Bay Area
    My 04 50K started handling funny when going fast on curvey mountain roads. It has good Michelin tires. I can't tell if the shocks are shot, a swaybar is loose or if a tie rod or something is worn -- this is what it feels like. It's going into the dealer this week but I wanted to get feedback here if there is any.
    Thanks,
    Al
  2. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
    Make sure you check your tire pressure stagger. Without the 2 pounds differential between front and rear, I find the handling is skittish and loose with plenty of over-steer, or perceived over-steer anyway.
  3. mary2al
    57
    SF Bay Area
  4. mary2al
    57
    SF Bay Area
    wowsers!! Never heard of such a thing in all my born days! I did just top them all up to 40lbs when I noticed the funny handling.
    I will try your idea asap -- but wait -- you say "differential" but do not say higher in front or back?!!?
    Thanks!
    Al
  5. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Front should always be 2lb higher than Rear. The Door Sill calls out 35/33
  6. mary2al
    57
    SF Bay Area
    Thanks, I'll change it to 2lb differential. Is the "door sill" a mfg sticker?
    I thought there was a huge concensus here for higher pressure -- even higher than my 40psi.
  7. Submarine Dude
    Submarine Dude Junior Member
    73
    Glendale, AZ
    Hmm, I run 44/44 and have never encountered any such problems with handling (still on OEM tires at 19K).
  8. KTPhil
    KTPhil Active Member
    1,379
    Rear-engined VWs ran 20 front/30 rear for the same reason: the weight distribution causes uneven tire stress, and the inflation differential helps the handling become more neutral.
  9. mary2al
    57
    SF Bay Area
    Culprit -- worn (1year old) tires were rotated to rear -- then 44/42 psi then install chasis stiffening plate.
    The handling problem discussed here would not be noticed by most Prius drivers. As stated it shows up "driving fast on mountain roads..." Someone who gets 19K on a set of tires would not feel this issue.
    Thanks for all the input -- very helpful!
