Strange HV battery problem?
Discussion in 'Gen 2 Prius Main Forum' started by Gino Veltri, Sep 4, 2021.
  1. Gino Veltri
    Gino Veltri Member
    413
    40
    So Ive got two identical 2005 pri, the one im concerned about has a newer toyota HV battery in it. Problem is , the ICE is running way too frequently and the MFD shows the HV battery drains even when the brake is fully engaged. Such that i have to put the car in park at red lights or itll just keep draining.
    Im thinking of switching the HV battery for the reconditioned one I built in my other prius because im worried this problem prius might hurt my newer toyota battery, does this seem reasonable?
    I have no reason to think the fans or ventilation is blocked but if anyone has any notes on determining that Im all ears. I also havent read the ABS codes in a while but i think it was some sensor , still not an explaination for the strange HV buisness. Sometimes the car throws p0420, if i havent disconnect the 12 volt in a long time but all prius with 1000000 miles do that, bad cat, oh well sorry envirnoment.
    A little info on this prius (was abandoned):
    I should mention that when i got the car the HV battery inside it had actually exploded and I never did determine how the hell that was even possible. The 12 volt wiring had also been cut out for some reason and the brake actuator?/accumulator? had to be replaced. Shortly after replacing it, i hit a bump and the ABS , !, and parking brake lights came back on and are still on to this day. The brakes seem a little weaker since this but still alot better than having zero brakes at all like when i first got it (yes i drove it to the shop with no brakes). I rigged up a wiring for the 12 volt and just have a large deep cycle strapped down in the trunk. I used to have to disconnect it several times to get the dash lights on but that problem seems to have stopped with a better ground connection.
    Pardon my spelling, i think my point gets across regardless, Thanks in advance for yall's help.
    52,841
    no trouble codes? do u have tech stream?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    I would suggest getting a mini VCI cable (alond with a bootleg copt of Toyota's Techstream diagnostic software) from ebay or amazon and installing it on an old windows laptop. This will let scan codes and data from all accessible modules on the car, and more.
    I would also get the Dr Prius app (or Hybrid Assistant- android only) along with a compatible Bluetooth OBD2 adapter to let you view HV battery ecu data on the go.
    You have two cars, which means you can look at battery data from the good car, snd see how the "bad" car is different.
  4. Gino Veltri
    Gino Veltri Member
    413
    40
    Oh man trust me i know, i got a OBD II interface (wifi) and usb but techstream isnt compatible with my mac/iphone and Dr prius is but i just cant get it to work even after paying for it. I can get some info from an app called Car Scanner but not detailed HV battery info. Thing is neither of my batteries are in great shape. One i rebuilt, ones from toyota but getting stressed by something else in the car. Have you ever heard of one blowing up? that piece of the puzzle scares me.
    Im thinking of installing 2 12 volt vans down there just to make sure theres good airflow but that sounds crazy. but I dont think ive ever heard the fan in the backseat come on in the problem car. The VSC ABS ! parking brake codes also cant be read through that scanner too , correct? If i recall someone once blamed it on a wheel ABS sensor (but he couldve just been trying to cover for a shotty accumulator/actuator/brake job too). I guess ill get out the wires and read some blinkys.
    The MFD showing the battery draining while at a complete stop I KNOW is not a typical prus behavior as they always turn off the engine and stop draining from battery when at a complete stop with your foot on the brake. When you lift your foot off the brake a little, then it is supposed to drain.....so could something not be sensing my braking ? In fact, as soon as you put your foot on the gas (of the problem prius), the ICE kicks in immediately as opposed to waiting till a certain acceleration level. or could something be pulling electrical power excessivley even at a stop? Oddly enough , in my other prius, thats operating normally-ish, I have a 12 volt at 10.1 volts and a subwoofer and amp setup (probably what killed my 12 volt) but it doesnt display this battery draining at a stop thing, just needs two button pushes to start ( i know im going to replace the 12 volt right now actually). But the problem prius has a brand new 12 volt (all be it rigged up to me fancy wiring replacement for the one cut out).
    #4 Gino Veltri, Sep 4, 2021
  5. Gino Veltri
    Gino Veltri Member
    413
    40
    If you could point me to a copy of techstream or something compatible with a mac ( i could even dig up an old windows laptop im sure) but from what ive seen its insanely complicated to use and im just not a technology guy. Im more of a jump start your prius with a drill battery kinda guy.....or is it the OBD II interface the problem? does the mini vlc specifically do something more? Thanks for yalls help again. These 2 little pri saved my life and got me the hell out of california and back to Colorado, so I want to keep them around a while. Nobody thought they would make it honestly.
  6. Gino Veltri
    Gino Veltri Member
    413
    40
    I guess you can never provide enough detail, right. I recently learned those colors of the bars means something, on my rebuilt (and maybe newer toyota battery) they go from blue down to 1 bar now sometimes, and then i just coast and it charges back to full green bars suspiciously fast. This is a sign of a bad cell , isnt it. I know both batteries were stressed hard by crossing the rockies in the weather we did, i always pulled over at two bars to let it recharge a bit. But ive never seen just one bar till recently.
  7. dolj
    dolj Senior Member
    8,646
    4,395
    Wellington, New Zealand
    1000000 (1,000,000) miles? Or did you mean 100,000 miles. If you mean 100,000 mi, I don't think it is acurate to say that they all do that at that point – they are barely broken in.
  8. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Inverter problem? 12v battery charging incessantly?
  9. Gino Veltri
    Gino Veltri Member
    413
    40
    lol no i just meant it has a ton of miles. almost 400,000 i think
  10. Gino Veltri
    Gino Veltri Member
    413
    40
    This is an interesting thing i hadnt yet considered. You mean thats why the HV battery is always draining even when stopped? Because the 12 volt system i have in there is NOT stock for sure (pics to come)
  11. Gino Veltri
    Gino Veltri Member
    413
    40
    But my other prius has a bad 12 volt in it (hold charge at around 10.5 volts) and it doesnt display this behavior
  12. bisco
    52,841
    tech stream will only work with windows. dr prius can be helpful
  13. Danny13pruisc3
    175
    28
    maryland
    Go ahead and dig out that laptop.. and get an old android phone and bluetooth adapter.. you'll learn to use it..
    I would recheck your ABS setup.. I hear if that isn't workiing right it will affect the charging.. or not charge or something..
    maybe a plug came out when you hit that bump? After i checked that out,
    I would switch the hybrid batteries just for a diagnostic standpoint.. then again it's easier to keep trying and get the dr prius ap working on an android phone. We're probably cut from the same cloth.. just go ahead and keep trying at getting dr priius to work on an android phone and once you do you'lll see it isnt' so bad.
  14. Danny13pruisc3
    175
    28
    maryland
    also where are you located? maybe another member here already has a setup and is local?
    Also try even a regular code reader and see what codes you can come up with..
    The $20 hypertough one at walmart has been handy for me and shows some hybrid codes.
  15. dolj
    dolj Senior Member
    8,646
    4,395
    Only if you have one at hand, and even then it won't really be helpful as the more helpful codes will be from the ECUs that a basic reader cannot read.
    In any case, do not waste money buying a basic reader. That money would be better spent on getting a decent Prius capable reader.
  16. Gino Veltri
    Gino Veltri Member
    413
    40
    I see, i have a basic code reader, only gives me the codes when a check engine light is on, which is always p0420, bad cat or maybe loose sensor (ive never changed it). ill get some windows / android action going here but am i correct in understanding this basic OBD II code reader is basically useless? So I need a prius specific code reader, right? The mini vlc? or....which? Which is totally worth it to me, considering Ive gone this far with one of my priuses. Sorry, Pri*. I know, its dirty but sometimes you gotta clean off your bench seat. in a prius.
  17. Gino Veltri
    Gino Veltri Member
    413
    40
    Also...could using a regular wet beep cycle marine battery affect anything? Its brand new, holds good charge. And prius puts out 14.1 ready as usual.i think.
  18. dolj
    dolj Senior Member
    8,646
    4,395
    That is not a code reader, it is just an OBD-II dongle. It needs to be paired with an app (the listing mentions a few) in order to diagnose. It depends with which app you pair it whether you can read all the ECUs. A lot of people recommend Dr. Prius, Hybrid Assistant, or Torque Pro.
  19. Gino Veltri
    Gino Veltri Member
    413
    40
    Welp, in my truest fashion, i took a kind of non issue and screwed it up significantly more. Now im talking about my OTHER prius. I had to replace the 12 volt , so while i was doing this i decided to poke around the H V battery. (Previously i mentioned wanting to switch the batteries but i decided the ABS system is the real root of the issue, after driving her for a few days.) sooo while i was switching the 12 volt anyway I wanted to make sure the fan wasnt clogged with dog hair, multimeter around the battery (even though i know this doesnt show the full picture of battery health)....I admit i did this opening and disconnecting then reconnecting in the dark at 3 am. When i went to start the car, it didnt want to switch into ready, it displayed the red triangle, and problem on the MFD. I could hear the relays open, it briefly said ready, then ready would dissappear. I did this 3 times, hearing a distinct electrical short noise the last time. Between each attempt I was pulling and putting back the orange service plug as i know this is a common cause for a brief red triangle....i reopened and found the main orange cables were not sinched down well at all. The car then started normally into ready, but the red triangle hasnt gone away, the battery discharged and charged rather quickly (but that was the issue i was originally investigating).
    Read the codes and its P0A0D and P3000, the orange service plug doesnt seem to sit right but for the life of me i cant get it to go in , and i have 2 spare orange service plugs. HELP!
  20. dolj
    dolj Senior Member
    8,646
    4,395
    Straight from the repair manual. For some reason people don't seem to want to do the third step:
    Raytheeagle and jerrymildred like this.
