Strange issue with vehicle and GPS/unlocker module
Discussion in 'Prius c Audio and Electronics' started by DocAwk, Dec 15, 2017.
  1. DocAwk
    DocAwk New Member
    Denver
    2016 Prius c
    Hi Everyone!
    Not sure where to take this next before giving up and going to the dealership. I've got a fleet of 12 rental vehicles. We've installed these trackers and they are working flawlessly on 11 of our cars:
    [LINKS NOT ALLOWED, PLEASE SEARCH "ATIAN TK103B+" ON AMAZON]
    These units are pretty slick. You set up your account, and are able to text message the cars to get the doors to lock/unlock, disable the starter, and see where it is parked.
    For whatever reason, our 2016 Prius C one doesn't like the module. The doors will not unlock after the car is parked with the doors locked for several hours. We know the signals are getting through to the GPS unit after extensive testing.
    Fortunately, the problem is 100% repeatable:
    1) Park the car, lock doors with either cell phone, key fob, or door switch (doesn't matter)
    2) Wait at least 5 hours - if this amount of time does not pass, the unlock commands work normally
    3) Send unlock command from cell phone - GPS unit responds "doors unlocked"...but nothing happens
    4) Send lock command from cell - You can hear the electronics firing inside the door, re-locking the already locked door
    5) Send unlock command again - Unit responds that it did something, but doors sit quietly locked
    For some cars, our GPS installer shop has had to put a "double pulse" unlock module to send two unlock signals sequentially. Even after installing that add-on, the symptoms of the problem remain the same.
    So, based on behavior, we're theorizing that the Prius is rejecting the electrical unlock command (even though it comes twice) after sitting idle for sometime. Is this some kind of battery protection in play? We know the GPS module is acting correctly, as we've swapped out the "brain" already with the same results.
    Since the installer is ready to give up, do we take this into dealer, or try to find a different professional? Thanks for any help or insight, this is causing our renters some unnecessary stress when picking up the car!
  2. Prodigyplace
    12,708
    11,847
    Central Virginia
    I think you need to contact the vendor of the system about compatibility.with the Prius c. They are the ones that should have the answer.
  3. DocAwk
    DocAwk New Member
    Denver
    2016 Prius c
    Good thought, except that we can hear the signal coming out of the box to the Prius C doors. To boot, this system works without issue on our standard 2013 Prius II.
  4. Prodigyplace
    12,708
    11,847
    Central Virginia
    Does the vendor support it on the Prius c, though?
    Unless there are other issues, I doubt the Toyota dealer could be of much help.
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    No doubt - nothing a Toyota dealer is going to do for you. They'll most likely tell you not to do it and be careful of what it would do to any vehicle warranty. Aftermarket stuff - and vehicle warranties don't usually mix well. lol
    Prodigyplace likes this.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I know there is a setting on these cars that they re-lock the doors if you don't open one of them after 30 seconds. Maybe try turning that off and see if it fixed it.
