Strange Noise at Start?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Susan4ET, May 25, 2018.
  1. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Couldn't figure out any way to search for possible answer already posted?
    Every once in a while--its happened maybe 5 times in 5 months...at initial Start in the morning (car is garaged)...maybe cold, < 50 F, maybe not...hasn't happened for some time now and weather is now much warmer (Central Oregon)...
    I hear a noise forward of the driver rather then rear of driver...either when pressing brake pedal before pressing Start or maybe not until Start is pressed too. I think the sound is mechanical but might be an electrical "buzz" that lasts for about 1 second only and stops and does not repeat. Thinking of something out of position that might move to reset to some nominal position? I then start driving and everything seems normal. Maybe something with a brake? I am not talking about the sounds that go on when the door opens which occurs every time. Nor the actual brake sounds. What I'm hearing is not normal but it also may not be of any concern either.
    Any ideas? I'm going to try to describe this to a Prius tech but if any of this makes any sense someone here might go right to the problem--or it may be impossible. Thank you.
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Can you do a short video?
  3. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    That happens in mine also. It's an audible buzz right when I press the brake pedal down just enough so the start stop led is lit green.
  4. RRxing
    RRxing Senior Member
    2,558
    1,833
    NEPA
    Sounds like the brake booster pump. Normal...
  5. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Yes I could but sadly, since I cannot cause the "rrrrrr" sound to occur, I don't see myself videoing starting the car every morning in the hopes of catching the sound. It must have something to do with something that runs for about 1 second when I initially push the brake pedal and/or the start button in the morning. In fact, my timing to post this is really to late because the noise is now a couple weeks overdue. I'm waiting to refine more exactly when during Start this occurs. I have cycled through all the air vent positions to no avail.:(
  6. bisco
    52,509
    but that happens when you open the drivers door. is it adding another second when you push the brake or start button?
    Grit likes this.
  7. bisco
    52,509
    susan, are you trying to hear things because you want a new car?
  8. RRxing
    2,558
    1,833
    NEPA
    Not necessarily...
  9. bisco
    52,509
    interesting.
  10. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    I just spent some time listening to and identifying all the sounds you have detailed above during Start but none describe the noise I very infrequently have heard. It is important to understand that this ~1 second noise is different from all the normal noises that clearly occur every time. I do notice now though that the air moving vanes/controls do "resettle" themselves (or it sounds like they do) after starting. I'm wondering if on occasion whatever this control device is it sticks making this "rrrrrr" noise I describe? I've cycled though all positions I can find though manually and none produce the trouble.
    It's possible there could be some trouble code. How many weeks/months back are these codes held for? If an air vent control/actuator had some difficulty would something like it produce a code?
    #10 Susan4ET, May 25, 2018
  11. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    I'll see if I can video this in next couple of days.
    Might be trading it in for a Honda Civic hybrid super soon Heh.
  12. bisco
    52,509
    maybe it is moving the engine into the start position, but i thought that happened when you shut it down.
  13. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    No codes, got techstream on win 10, and nothing.
  14. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Would like to describe this ~1 second sound as an electric motor or solenoid "growling" maybe. Anyone know how easy it is to get to/examine the air/heat/cold vent actuators/solenoids? I suspect they are under the dashboard which would require disassembling the whole interior?;)
  15. bisco
    52,509
  16. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I'm sorry, as long as there aren't any videos, it might very difficult for some of us to help with solutions.
    You might need someone with some kind of experiential knowledge of such a noise, to be able to decipher the noise here.
    This is a very difficult tasks.
  17. padroo
    padroo Senior Member
    2,763
    2,252
    I drive in ignorant bliss with bad hearing. If I need to hear something I call my wife.
    I do feel different vibrations from the car at different times.
    Raytheeagle likes this.
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    For the first post rrxing got it right it’s the brake vac assist motor. Wanna hear it?
    Just push the brake pedal a few times. Sounds like a rattle snake. Normal.
    #18 edthefox5, May 25, 2018
    padroo likes this.
  19. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    To test the brake booster/accumulator sound:
    DO NOT OPEN the driver door in the morning.
    Open the passenger door and climb over to the driver side. Start the car and listen for said sound. It will be longer as the brake fluid accumulator fills from scratch.
    I suspect this is the sound...
  20. edthefox5
    10,096
    4,834
    Clearwater, Florida
