Strange noise going into reverse in 2022 Prius LXE
Discussion in 'Gen 4 Prius Technical Discussion' started by atterbury90, Sep 30, 2022.
  1. atterbury90
    atterbury90 Junior Member
    53
    22
    SE Pennsylvania
    2022 Prius
    XLE AWD-e
    Anyone with a 22 Prius notice a strange noise going into reverse. It almost sounds like a vacuum leak, sort of high pitched like wind rushing? Just wondering. I own a 2017 Prius and no such noise. Car is 2 weeks old.
    Thanks. I know there aren't too many 22's out there, at least in the U.S.
  2. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Is it possibly the back up warning sound (it is a pretty strange sound, but only there if the car is in EV mode (ICE not running))? Sounds like some sort of space ship sci fi sound.
    atterbury90 likes this.
    52,838
    that is a pedestrian warning, backwards or forwards
  4. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    Significantly louder in reverse.
  5. bisco
    52,838
    interesting!
    Doug McC likes this.
  6. captqc
    captqc Member
    70
    43
    Oregon
    2022 Prius Prime
    My 2022 xle “safety sounds” are significantly louder than my 2012 Prius C was. Guess too many people were getting run over!
  7. atterbury90
    53
    22
    SE Pennsylvania
    2022 Prius
    XLE AWD-e
    Thanks Doug.
    Do you know if it is mentioned in the owner's manual. I must have missed it.
  8. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    In section 1-4 it mentions it, but I couldn’t find any place else with a quick look and it doesn’t mention the increase in volume (at least I couldn’t find it if it does). When I’m pulling in and out of my driveway the volume level change is really noticeable! :)
  9. atterbury90
    53
    22
    SE Pennsylvania
    2022 Prius
    XLE AWD-e
    Thanks all. Learn something every day. I had no idea on my 2017 that when I go forward it was for that purpose. No sound in reverse, at least that I could hear over the back up beeper. Anything to help pedestrians avoid injury, at least those without headphones on.
  10. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    My ‘22 beeps once when I put it in reverse. I can’t remember if I set it that way under the customization settings or used Carista. Speaking of learning something new, just today I realized that one of the beeps I heard as I was backing out of the garage was a single beep when the backseat seat belt light lit up with no one in them! Not sure if that is what it is supposed to do or not, but one beep doesn’t really matter in the grand scheme of things. :)
  11. atterbury90
    53
    22
    SE Pennsylvania
    2022 Prius
    XLE AWD-e
    HMMMM
    hmmmm..... I'll have to look out for that.
