Strange noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bear4, Dec 4, 2014.
  1. bear4
    bear4 Junior Member
    68
    17
    FL
    Has anyone noticed a weird metallic rattling noise coming from the transmission when switched to N with the engine running and the car is stationary? Almost like the gears are rattling inside while in N position. I took it to the dealer and their Prius guru said this is normal characteristic of eCVT....
    Thank you!
  2. CR94
    CR94 Senior Member
    2,792
    1,227
    Northwestern S.C.
    If that's indeed a "normal characteristic," I'd guess it occurs for the much same reason the my old 3-speed Sturmey-Archer bicycle hub rattles when there's zero torque on its planetary gear system.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Is it continuous or only when switched?
  4. bear4
    bear4 Junior Member
    68
    17
    FL
    It is continuous while the ICU is running and the car is stationary in N. Does not happen is the car is in motion
  5. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Yeah, it's normal
