  1. Ashley Youngblood
    Ashley Youngblood New Member
    Pasadena, TX
    I am literally freaking out over this noise. Has anyone experienced it before? It's really silent, so I'm shocked that my phone picked it up. It sounds to me like it is coming from under the left side.. Under my dashboard.
  2. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I believe that's the coolant control valve. The '07 does that after power-up. I believe it can cause a trouble code to appear, but it hasn't in my case. I read that it isn't likely to cause problems, it may just increase the time for the coolant to warm. I haven't done anything about it...I just ignore it.
  3. Ashley Youngblood
    Pasadena, TX
    Good to know. It randomly makes the noise and then randomly doesn't. My car doesn't act weird or anything. Thank you for the response. I feel like I can breathe now, lol. I'm so glad I found this website!
  4. DRACO
    DRACO Member
    362
    77
    Rancho Palos Verdes, California
    2002 Prius
    +1 Control Valve and/or Pump. Once failed, it will raise the temps in the coolant and throw the error code.
  5. Ashley Youngblood
    Pasadena, TX
    I haven't had an error code pop up yet. Is that when I should worry?
  6. DRACO
    DRACO Member
    362
    77
    2002 Prius
    Pretty much, the noise is the valve or the pump laboring prior to failure. Depending on use, it may take awhile or suddenly.
    When the car is in "ON" ( not READY ) can you see the fluid flowing rapidly in the reservoir? If so, you are good to go. Once in awhile keep an eye on it. if it stops flowing in a rapid state, it is time to replace the pump and or valve.
  7. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I thought the coolant control valve was in the engine coolant loop and not inverter coolant loop. Isn't that right?
    In more reading, I read about the theory that low engine coolant levels can cause the valve to stick. You might also check the level of the engine coolant at the radiator fill neck. It's under the large, black plastic cover across the front of the engine compartment. Just removing the few snaps on the cover in the front, passenger side corner is usually enough to pull it up a little and remove the radiator cap (only when the engine is cold). The coolant should be right up to the cap.
    Ashley Youngblood likes this.
  8. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    It's the three-way coolant control valve and it is in the engine circuit. Mine did that for tens of thousands of miles before it finally broke and I got the code. I got so used to it, when I replaced the valve and it was quiet again, it took a while to get used to the silence. You should probably fix it sooner than I did. If it breaks in the wrong position, you won't have cabin heat, I hear.
    Good advice above about checking coolant in the COLD radiator.
  9. Ashley Youngblood
    Pasadena, TX
    Sorry if this sounds dumb, where exactly is the reservoir? I've had my car for 3 years and hardly know where anything is. I'm glad I found this chat! I'm ready to learn more about my car.
  10. DRACO
    DRACO Member
    362
    77
    2002 Prius
    You should have two if a HV.
    The ICE ( Internal Combustion Engine ) has one and Your Electric Motor (Inverter) has one. If unsure check with your manual the reservoir locations.
    Members are leaning towards the ICE reservoir. Locate that one and check the level. It would not hurt to find the Electric one too to insure it is rapidly flowing in the reservoir.
    Google is your friend, PC also :D
    #10 DRACO, Jan 20, 2016
  11. Ashley Youngblood
    Pasadena, TX
    Here is another video.
  12. DRACO
    DRACO Member
    362
    77
    2002 Prius
    Okay that goldish cover is your Inverter, now look to you left, you should see a reservoir with red colored fluid, is it flowing rapidly?
    I hear the isolating pump noise then it stops then a light continuous hum ( not the HID hum ), right?
    In order to access the ICE radiator cap, you need to remove the black cover as stated by a member.
    #12 DRACO, Jan 20, 2016
  13. Ashley Youngblood
    Pasadena, TX
    I'll dig into this on Saturday and get back with you. Super busy with work the next two days. I'm off then. Again, thank you so much! I'll be back on here Saturday :)
