Strange occurrence
Discussion in 'Gen 3 Prius Main Forum' started by Steelholder, Dec 9, 2022.
  1. Steelholder
    Steelholder Junior Member
    73
    17
    Encino
    Hey all, had a strange thing happen yesterday on my 2010, 110k. I started the car and the engine turned on but right when the gas engine shut off (warmed up) it started up again immediately, stayed on for about 4 seconds then turned off and once again started up immediately. Did this about 5 times before I turned the car off. Hasn't happened before, any reason why this could have happened? No codes were thrown, drove well after restart.
    52,857
    have you cleaned the egr circuit?
  3. Mendel Leisk
    42,348
    If you monitor the coolant temp (with a third-party app/device) you'll see it's not fully warmed (say 190~195F) when the car first shuts off. That behavior is a little weird, but maybe it was just dancing around the threshold for shut down.
    Did you have the heat/vent system on, asking for heat? Might be a factor.
  4. Steelholder
    73
    17
    Encino
    I was gna clean the egr ports on IM but when I removed it they were very clean, no build up. I haven't removed the cooler or valve but my airflow is good around 18.5 kpa on average
    I thought the same. Heat and ac were off.
    Mendel Leisk and bisco like this.
  5. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    I've never encountered that strange behavior, but have had a simpler version, possibly related. That occurred when the engine was partially cooled after being shut down for maybe 30 minutes in mildly cool weather. When I pressed the start button, the engine started, but stopped after running only roughly one second.
