Strange SKS behaviour!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by WilDavis, Aug 24, 2021.
  1. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    For the past couple of weeks, I have noticed strange happenings occasionally when I try to unlock or lock ChuggyPyg (2009 Gen II Prius). It's like the system gets into a loop where the locks unlock, then they keep repeating the cycle, lock/unlock/lock/unlock and eventually the cycle stops. More often than not, all the doors are unlocked, however the driver's door is still locked! (and the dome lights are on!). The weather here in the North East has been burning hot for the past couple of weeks (temp inside car = 130ºF :eek:) I am wondering if other readers have suffered similar problems, and perhaps ChuggyPyg is suffering from heat-stroke???:(
    I thought perhaps it might be the fobs but I checked and even replaced the batteries, all to no avail!
  2. JC91006
    16,827
    8,600
    Maybe there's a bad ground somewhere
    WilDavis likes this.
  3. WilDavis
    2,493
    2,155
    49
    Good suggestion! ChuggyPyg has appointment for oil/filter change later in the week, perhaps MrToyotaStealership might have some ideas! :unsure:
    52,371
    check the 12v health and cable connections, especially neg to ground
  5. PriusCamper
    PriusCamper Senior Member
    13,030
    5,295
    Pacific Northwest, USA
    Your Fob could be the problem. Is the red light that blinks when you push a button on it sometimes light up when you don't push the button?
  6. WilDavis
    2,493
    2,155
    49
    Both fobs seem to work OK, I changed button-cells just in case, but thanks for the suggestion!
  7. Neicy
    Neicy Member
    834
    Wakefield, MA.
    +1 (Quote didn't work - operator error) bisco is correct.
  8. WilDavis
    2,493
    2,155
    49
    Well, the problem seems to have disappeared along with the heat/humidity the North East has been subjected to for the last few weeks! :):rolleyes:
