Strange sound after engine turn off in 2015 Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Aqua2014owner, Jun 9, 2018.
  1. Aqua2014owner
    Aqua2014owner New Member
    29
    Karachi Pakistan
    2014 Aqua
    Hi Everyone
    A friend having Prius C 2015 says he hears a strange sound like a water pump working, after the engine is turned off. I have never heard a similar sound in my 2014 Prius C, can someone help?
    52,839
    it just depends on the circumstances. both can be normal.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Brake booster, I believe. The booster in this car (along with the evap system) will sing to you for a few hours after you shut the car off.
  4. Talha Maqsood
    Talha Maqsood Member
    46
    26
    Pakistan
    2015 Aqua
    Yes i hear this strange sound in my 2015 Toyota Aqua, i think it has something to do with AC as when i didn't use AC i turn off my car no sound, when i use AC then turned OFF the car this sound i hear for few minutes like 5-10 min
  5. Mike4kz
    Mike4kz Junior Member
    I already used to this... Just unlocked the car... Sit on the driver seat... And car starts breathing... clicking.. something is moving (but I don't see it). As my wife says "car wakes up"... Then I put a key and start the car... I stopped wondering...
    PS. I know Subaru XV (hybrid) has "automatic louver" that keeps it open until car warms up, and then opens as needed to allow air to cool off the engine. I don't know, if Prius has something similar...
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    The C does not, but it would be nice if it did.
  7. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    AC on? After it shuts down, there is still liquid refrigerant being metered by the TXV into the evaporator. It'll make this noise for a few minutes until the pressures in the high side and low side equalize.
    Talha Maqsood likes this.
  8. Hawaii Magic
    Hawaii Magic New Member
    Hilo, Hawaii
    2014 Prius c
    When the driver's door is opened, the anti-lock brakes pressurize. The noise you hear is probably that pump running. The c has many relays, beeps and click noises all the time since it never is really off, even when it not running.
