Strange starting problem
Discussion in 'Prius c Technical Discussion' started by jerryd, Feb 9, 2019.
  1. jerryd
    jerryd Junior Member
    53
    Florida USA
    Prius C forum,
    My wife's 2012 C II with 30,000 professionally maintained
    miles had sat for several days. When I tried to start it
    it acted like a non hybrid with an almost dead 12 volt battery.
    The dash lights came on and it said "powered up" but every
    time I tried to put it in gear it said "shift into park".
    The headlights were dim and the windshield wipers ran very
    slow. The radio came on but if I stepped on the brake there
    was a popping sound and the radio went off. Let off the brake
    and the radio would come back on.
    I jumper cabled another 12 volt battery with the one under the
    back seat but it didn't change anything. I turned the car off
    and let it stand for about 5 minutes, jumpered battery still
    connected. When I started it again everything was normal
    and the traction battery was all charged up. I drove it around
    for 15 minutes, let is sit for 4 hours and it started as normal.
    Any ideas as to what the heck happened?
    Jerryd
  2. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    I'm going to beat "Bisco" here and ask how old is the 12volt battery?
    bisco and Raytheeagle like this.
  3. jerryd
    53
    Florida USA
    The 12 volt battery is original but for 2 days now everything has been fine.
  4. scona
    scona Active Member
    225
    207
    2013 Prius v wagon
    Then the 12-volt battery is going on 6 years of age now. That is generally as long a life as can be expected from them. When they start to fail all sorts of strange electronic behavior starts to happen, and generally continues until the battery is replaced. Just a heads up, the 12 volt is probably on the way out.
  5. jerryd
    53
    Florida USA
    OK I'll take the battery out and have it checked. What is going to have to
    be "reset" after I replace the battery?
  6. scona
    scona Active Member
    225
    207
    2013 Prius v wagon
    I can't think of anything that needs to be reset when changing the 12 volt. You do lose some information like the radio presets and some data from the accumulated mileage calculations gets wiped out. So for a bit it will seem like you are getting poorer mileage then before the battery was changed. Which is not true, it is just a computer thing. Nothing wrong with just continuing driving until some more strange electrical things start happening then change it out. I changed a battery some 6 months ago and replaced it with an OEM (Toyota) battery, which I am happy with. Warning, these are small batteries but are not cheap to replace.
  7. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I've disconnected the 12v in ours a few times when installing and adjusting the aftermarket stereo. I don't recall having to reset anything beyond the radio presets.
    Some cars need to re-learn their idle or power windows, but the c seems to get away with a smaller blackout penalty, more like an early 90s car.
    I don't know how to explain why the connection to the second battery didn't immediately help, but possibly the electrical contact was poor at first and slight vibrations improved the grip of the spring jaws after a minute or two. Either way, a gentle cross-charge is by far the safest way to do an electrical rescue on one of these cars. So even if it was by accident, it was for the best.
    I agree with the base diagnosis, your factory 12v battery is pining for a fjord. The only direct-fit replacement I'm aware of is exclusively sold across the dealer parts counter for about $200 and would take a careful DIYer about 30 minutes to install. You can get similar generics but they all require one adaptive compromise or another and they don't really save much vs. the real deal.
  8. bisco
    52,863
    mine will be 7 years in april, probably now if you figure when they built it.
    scona likes this.
  9. fuzzy1
    10,714
    When I replaced my Liftback's battery last week, I left the ignition turned on and Ready during the swap so that nothing would need to be reset. This is an advantage of the Prius electrical system, once the car is started and Ready, it can run without the 12V battery in place.
    Checking a voltmeter, it seemed a bit high, so I turned on the headlights to make sure the HV->12V inverter had a reasonable mimimum load to stay in regulation. And that did bring the voltage down to normal running level.
    The swap then went quickly and smoothly, no problems. Do be sure to disconnect the negative cable first, reconnect it last, and keep the positive cable from touching any nearby metal parts.
    ztanos likes this.
  10. Mary Carrier
    Mary Carrier New Member
    sacramento
    I just found out that my starting problem was due to a low key battery....I replaced it and since then no problems....previously I had taken car in to check 12 volt battery and had to jump start it several times.
  11. bisco
    52,863
    there would be no reason to need a jump start due to a low key battery
    ztanos and scona like this.
