Strange Thing...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TwoPriusInTenn, Nov 23, 2020.
  1. TwoPriusInTenn
    254
    66
    Tennessee
    2004 Prius 300,000+
    Strange thing happened on my way home tonight. Car lost all power and displayed the triangle of death and other dash lights. I pulled off the road and powered it down. When I push the power button again all dash lights came on again but only for a second or two. It also displayed five squares (is this a clue?) on the right side of the combination meter. There was a faint scent in the air that I thought might be coolant, but all levels looked good. It will not start and combination meter will not stay on.
    I have tech stream on my laptop but I don't think the car will stay on long enough to read the codes.
    Any ideas or suggestions?
    #1 TwoPriusInTenn, Nov 23, 2020
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    When was the last time the inverter coolant pump was replaced (DTC P0A93) ?
    TwoPriusInTenn likes this.
  3. TwoPriusInTenn
    254
    66
    Tennessee
    I have never replaced the cooling pump. I did swap out the inverter a couple years ago, but not the pump.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Well guess what?
    The pump shorts out and blows am2 fuse in the black fuse box in the engine compartment.
    Do not replace the fuse it will just blow again. Pump must be replaced
    First.
    Use search forums link above and search:
    Inverter pump
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    You might check if the pump is functioning, feel for vibration by using a finger or stick, also look in the reservoir for liquid turbulence.
    Try disconnecting the inverter coolant pump (picture below), and replace the AM2 fuse, does the vehicle start now?
    Be sure to replace and reconnect the inverter coolant pump before driving again.
  6. TwoPriusInTenn
    254
    66
    Tennessee
    I replaced the pump with a used one. It is still blowing the AM2 fuse so my guess is that the newly installed pump is defective as well. I was able to pull the codes after installation P1121 and P1122.
    I also pulled a P3102 that I think was a result of having it towed home this morning.
    #6 TwoPriusInTenn, Nov 24, 2020
  7. TwoPriusInTenn
    254
    66
    Tennessee
    Thank you. I figured out which fuse it was. Replaced it and unplugged the pump. I was able to start it up. Now to replace the pump. Thank you for your help in diagnosing this. Very grateful for you both. Thank you.
    SFO likes this.
  8. TwoPriusInTenn
    254
    66
    Tennessee
    UPDATE: Thinking I was replacing the inverter coolant pump, I was actually replacing the coolant flow control valve. Crazy mistake!! Argghhh...
    This explains why it is still blowing the AM2 fuse.
    I will replace the inverter coolant pump (right behind the driver's side headlight) tomorrow. Hopefully, this will fix it all.
    #8 TwoPriusInTenn, Nov 24, 2020
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    You replaced the engine water pump? Hope not that requires a pretty meticulous bleed to get the air out.
    Use a new Denso inverter pump or you will be right back there doing it again. This requires a good air bleed too to work properly.
  10. TwoPriusInTenn
    254
    66
    Tennessee
    FIXED!!!
    Inverter coolant pump replaced.
    No codes!
    No leaks!
    No air in the system!
    No blown fuses!
    Thank you for your assistance.
    Mycaleum likes this.
  11. TwoPriusInTenn
    254
    66
    Tennessee
    In addition to making the correct replacement, it is important to bleed all the air out of the coolant system. Runs like a charm now!!! Thank you again for all your help.
    #11 TwoPriusInTenn, Nov 26, 2020
  12. Mycaleum
    Mycaleum New Member
    Utah
    Well diagnosed and remedied.
