Strange tire wear -- Any thoughts? Google finds similar
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Oct 23, 2013.
  1. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Which is basically a load-activated system as I mentioned above, and only counteracts the natural tendency of a RWD vehicle to toe out under deceleration. It's still a standard suspension linkage, and it still must be aligned as usual. It seemed that hill was referencing something where the car was actively changing suspension angles according to some input, and that I had never heard of before.
    Hill - any changes to camber and caster that are made in your Land Rover are probably only a result of the natural change in these angles as you raise or lower any cars suspension. I'm not familiar with the specifics of how it's done in the LR, but I would bet that they designed the linkages to have minimal angle change over the range of height adjustment.
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Not everyone has the training to know how to apply it, but String Theory is just fine. ;)
  3. Mendel Leisk
    41,477
    Wait a sec: isn't String Theory some new space-time continuum postulate ;)
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Isn't that the TOE being discussed? :)
