Strange Whirring Noise
Discussion in 'Gen 5 Prius Technical Discussion' started by 16suirp4, Oct 26, 2023.
  1. 16suirp4
    16suirp4 Junior Member
    Orlando, FL or O'Fallon, IL
    Hi! I need help diagnosing a very loud & strange whirring noise on my brand new, 2023, Prius Limited, with 450 miles. I suspect the hybrid motor since it only occurs when it is engaged.
    I took it to the dealership today, but they didn’t hear anything…really!!! It’s bad inside and really loud standing outside. I have a video, but I can’t get it uploaded !
    Thanks!
  2. PickyAudioGuy
    PickyAudioGuy Junior Member
    16
    Chicago
    I'll take a crack without the video... My wife noticed my Prius first time i drove her in it. As an engineer I recognized the sound as being normal for an EV car. Does the sound get kind of high pitched and hissing like? The EV part of the prius has pulse switched power controllers that make noise due to the high currents being applied to the motor in variable pulses. This controller take the couple-hundred Volt battery and converts it to a variable power source to control the motor when in gear. It will vary somewhat with how much load is on the EV motor. Hope that wasn't too technical.
    52,817
    are you sure it's not the pedestrian warning system?
    watch
  4. Gokhan
    Gokhan Senior Member
    6,712
    2,661
    Paramount CA
    That is the normal EV sound that comes from the pedestrian-warning loudspeaker inside the front grill. It will be louder in reverse gear. If you don't hear it, there is something wrong. LOL
  5. jeremnyc
    jeremnyc Junior Member
    95
    2023 Prius
    Yes, in EV mode, you hear it. It's like a whirly white noise?
  6. PickyAudioGuy
    16
    Chicago
    OMG... Can you disconnect that?
  7. bisco
    52,817
    if you put your mind to it
  8. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    The sound turns off once you reach 23 mph.
