Streaming iPhone music via Bluetooth?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by AJP, May 27, 2016.
  1. AJP
    AJP Member
    124
    I read online that the Prius Gen II is only capable of interfacing with the phone part of an iPhone. Someone on Yahoo Answers suggested this product. What's the most common way to hook up to stream music from one's phone?
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yup, gen 2 is only for BT voice. I use this product.
    I recommend it if you only care about BT audio. If you want it for BT voice then it is not ideal because the microphone is too low due to the location of the 12V socket in the Prius.
  3. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    I just use the auxiliary plug in the console assuming your car has one. A little hassle to plug/unplug each time, but the sound is good. I did have to buy an inline noise reducer though to cut the static.
    dave
  4. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    I got this... Plug into your cig lighter and into my AUX in the center console.
  5. Jeff O'Connor
    Jeff O'Connor Junior Member
    Stratford, CT
    Hello all! New to the Prius word here, but loving it!
    I was really shocked at the noise you get when charging and having the AUX plug in! and way around that?
  6. mmmodem
    2,732
    1,703
    Bay Area, CA
    Ditto! You can get an expensive insulated cord or you can do what I and get a BT AUX adapter. ~$20 On Amazon.
  7. umerhabib
    umerhabib New Member
    pakistan
    i don't know how to post in Prius chat ........can anyone help me please
  8. slipsibm
    slipsibm Junior Member
    holliston,ma
    There was actually a recall /TSB on this issue. I had the work done several years ago. Check the TSB section of prius chat for details.
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    that parts for this tsb are stupid expensive, and Toyota has closed it, so they won't take care of it. for about $25 you can get a "ground loop isolator" cable, which helps a lot.
    Jeff O'Connor likes this.
