Stripped rusted bolt on module, solutions?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenTea&SaltWater, Sep 16, 2023.
  1. GreenTea&SaltWater
    199
    58
    Los angeles
    Wondering if I can pluck it out and put this bolt from another cell into it, which came off on its own. Or if maybe I can clean up the rust and solder onto the bus bar?
  2. ChapmanF
    19,016
    I think I'd buy a module.
    Brian1954 likes this.
  3. GreenTea&SaltWater
    199
    58
    Los angeles
    Would take about 5 days to receive one through mail, need a fix now.
  4. Leadfoot J. McCoalroller
    8,288
    7,800
    Pennsylvania
    2018 Prius c
    You can probably get that clean enough with a wire brush, but I would not attempt to replace the stud.
  5. GreenTea&SaltWater
    199
    58
    Los angeles
    It's not just the rust, the threads are stripped. It's just a nub atm. I'm gonna try spot welding it with my spot welder I use for building ebike batteries which I get a new one within the next 2 days.
  6. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Spot welding will possibly damage the cells and could result in an explosion... Just put smaller diameter threads on it and a smaller bolt and be careful to make sure it doesn't snap when tightening and order a replacement module from professor Joe: https://2ndlifebattery.com/contact-us/ because it's gonna run hot and is just a short term fix.
    GreenTea&SaltWater likes this.
