Structure of Driver's Seat
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jhsteel82, Aug 26, 2014.
  1. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    I think it would be interesting to see if a qualified body repair person would find this car has previously suffered damage from a rear end collision. And you can forget about what a Carfax report might show because the best they can do is report what has been reported to them. You can imagine how that works.
  2. jhsteel82
    jhsteel82 New Member
    Austin, TX
    The car is not under warranty. I am approaching 108,000 miles on the car and have had it in my possession for almost a year now. The car was never in an accident (clean Carfax report) and was purchased from a Honda dealer. The fact that the car is not under warranty should not even be a question in this case. This seat is supposed to withstand an accident no matter how old or how many miles are on this automobile. I am on my 15th car and have NEVER had this happen, which is why I am torn and not sure where to turn. The issue has been reported to Toyota Corp and they are throwing it out because of the age and mileage of the car. I repeatedly told them that this is a serious safety issue and needs to be addressed! They just repeated themselves and offered no help.
    The seat that I am looking to replace this one with was in a Prius that has been rear ended and I am afraid that this seat will do the same thing after having been in a rear impact. Just don't want to have to go through all the work and money to have to find out the new seat acts the same if not worse.
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
  4. Okinawa
    1,333
    320
    Your car is out of warranty so obviously you are going to have to pay to get it repaired. Why don't you just take your car to a Toyota dealer and have it repaired?
  5. LOLGuy
    LOLGuy Member
    177
    22
    Tampa, FL
    As best I can tell, the actual remedy to the situation is still unknown. That said, there are two choices (three, if you include do nothing): pay to have the seat replaced or pay to have the problem diagnosed. As a diagnosis is more than likely going to cost you anyway, if it was my car, I'd have the seat replaced. Do a quick check for possible seats but get it taken care of. If there is a structural issue, you don't want to have the consequences manifested in an accident. Good luck!
  6. Den49
    Den49 Member
    498
    272
    Maryland
    jhsteel82,
    The driver's seat in my 2010 Prius made a metallic click upon acceleration and braking much like what you are describing. The noise is harmless, but very annoying. I tried for about a year to find the cause and finally found that one of the locking pawls for the seat fore-aft travel adjustment was allowing the seat to shift in its track just enough to make the click. I bent the pawl to tighten it and the noise went away. All of this alarmist "you are going to die in an accident" talk is way out there in left field. Just inspect, or have someone else inspect, your seat. Any serious damage will be obvious. If there is damage, replace the seat. More likely, no serious damage will be found and you have just another Prius type annoying noise to deal with.
  7. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Where are people coming up with the opinion that it is incumbent upon the manufacturer to keep a vehicle in safe working condition in perpetuity?
    You purchased a used car from a non-Toyota dealer. The vehicle has over 100,000 miles on it and is somewhere around 60 month old. Things are going to break. Just because things break doesn't mean they are defective - it means they're old. The fact that you've on your 15th car and have "NEVER" had this happen means nothing. For all we know, you've leased your last 15 vehicles and never owned one outside of warranty, so let's skip the histrionics and try a different approach -- applying logic & common sense.
    There are a multitude of items which could be construed as safety-related. Just because they break or wear out doesn't mean Toyota has engineered a "defective" product, nor does it make them responsible for the repairs. If you're truly concerned for your safety, then the only logical thing to do would be to source a new seat directly from Toyota. Somehow, I don't think that will happen.
    The Electric Me likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I wouldn't expect Toyota to cover this under warranty.
    Yes it's a "potentially" a safety issue.
    But it's a 4 year old vehicle.
    Worn out tires are a safety issue. But Toyota makes replacement and maintenance of them a owner responsibility.
    I'm sure Toyota does design the seats in all their automobiles to be as safe as possible, and be durable and long lasting.
    But they can't be responsible for everything that might happen to a seat over the course of many, many years.
    On a higher mileage, 4 year old used Prius, I'm afraid the responsibility is the owners.
    chrisj428 likes this.
  9. Thetonka
    Thetonka Junior Member
    53
    SoCal
    Has there been an update to this situation?
    I realized after driving my wife's Prius that my seat had a problem. I checked and something is definitely broken. The back of the seat has several spots where the steal from the seat is poking through.
    Has anyone replaced the factory seats with after market seats? If I have to replace the seat I want to put something in that is more comfortable. I spend 3-4 hours a day in the car and have never liked the seats. I stopped by PRP seats last week to see what they may have. We have a set of the UTV suspension seats in our Rhino and love them.
    Since we have decided to keep both Prius's instead of upgrading(I'd rather have the cash we are getting from selling some toys than spend it on a new car), we are going to spend some money on upgrades for these(new sound systems, some paint work, seats, tint, floorliners, etc).
    PRP have a Daily Driver series of seats including the Rally Venture. They recline and can be ordered in pretty much any color. Obviously I won't need the race harness accommodations, but the lumbar and crotch support is really great. These would be a HUGE improvement over the factory seats, and would probably help my mood during the day since they will cause less fatigue from my 1.5+ hour commute to work.
    PRP Rally Venture Seats
    RallyVenture Reclining Suspension Seat | PRP Seats
    Any thoughts?
    Thanks
    #29 Thetonka, Nov 16, 2014
  10. jhsteel82
    Austin, TX
    Just to shed a little light on this situation...the seat that I had found in the salvage yard was way worse than the current seat. The whole frame of the replacement seat was twisted, but yet the salvage yard called it "Grade A" condition. So needless to say I got my money back. I haven't done anything with the seat thus far. It doesn't seem to be getting any worse so I am living with it for right now. Thanks for all the suggestions!
  11. GregP507
    GregP507 Senior Member
    3,002
    481
    Without looking at it, it sounds for all the world like the clicking was a crack, and the snap, was it finally breaking loose. Reaching for a wallet usually puts a lot of strain on the seat (I've broken a seat that way myself).
    If they tore it apart and didn't find the break, that doesn't mean it's not there. Replacing it is a good idea, and I doubt you'd be able to prove that it was defective, because you didn't report it as an issue earlier-on. You might find someone who could weld it, but that's not always a long-lasting repair, and it might cost you almost as much as the used one.
