Struggles uphill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gloria&Suzanne, Jun 28, 2026.
  1. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    81
    Sacramento, CA
    My 2013 Toyota Prius with almost 213,000 miles on it struggles uphill and revs loudly (rpm possibly too high) and loses power on steep hills. My car more often experiences sluggish acceleration once the engine warms up. I cleaned the EGR system a few months ago, replaced the PCV valve after discovering oil pooling at the bottom of my air intake manifold, in which yesterday, I discovered a recurrence of the oil issue and cleaned out the air intake manifold. And that the oil pressure sensor seal broke and oil started leaking out of that. The lower oil pan is leaking around the edges so I'm going to replace the oil pan seal.
  2. Brian1954
    Brian1954 Senior Member
    2,689
    1,076
    South Central PA, USA
    How many years have you owned the car?
    Do you have a long-term history of the work and maintenance done on the car?
    Back on May 8th in a different thread you wrote:
    What did the mechanic find and fix if anything?
    Did the high temperature warning light come on when the car was overheating?
  3. Higgins909
    Higgins909 Member
    289
    71
    Is the hybrid battery original and what kind of bars is it at when this happens?
    Brian1954 likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    It is normal for the engine to rev high on a steep uphill, the kind where you normally are slowed down.
    As noted in another thread, its most important to know what your engine temperatures are at that time, not how much the transaxle is gearing down.
    Review this post
    Can a water pump go bad with no check engine light? | Page 3 | PriusChat
    Finally oil in the manifold is normal and a new pcv does not solve it. It can be minimized with a high quality $200 pcv line catch can system but won't solve current issues like rattling, oil leaks or poor acceleration.
    #4 rjparker, Jun 29, 2026
    Higgins909 likes this.
  5. ChapmanF
    19,033
    The RPM won't go too high in a Prius, because that's all under the control of a computer that knows what the limits are. It might go higher than your personal listening preference, but that's a different matter.
  6. Higgins909
    Higgins909 Member
    289
    71
    IIRC, it will hit 5,200-5,400.
  7. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    More so than the same Prius did on the same hills in the past? If so, you actually have a problem. If not, that's normal Prius behavior, as was explained to you in another thread a few days ago. Especially at moderate engine speeds, a Prius engine produces relatively low torque in proportion to the weight of the car. Therefore, there's no way the car can speed up a steep hill without "revving loudly."
  8. ChapmanF
    19,033
    Yes, the gen 3 engine HP output peaks at 5,300 and then drops off, and the ECU knows that.
    A teenager might choose to rev an engine above that point sometimes for the sake of hearing snarly sounds even though it's less power. The power management control ECU in a Prius would think that was silly.
  9. Gloria&Suzanne
    81
    Sacramento, CA
    Yes, the behavior has changed. I found out there is a recall on my car still pending and I scheduled to take that in for that tomorrow. It's related to the inverter and computer software. My oil pan is leaking and my oil pressure sensor switch seal broke, and this Despite cleaning the EGR system and replacing the pcv valve, oil started pooling in my air intake manifold, yet again. I cleaned it out. It improved the issue a bit. I'm replacing the oil pressure sensor switch.
  10. Gloria&Suzanne
    81
    Sacramento, CA
    My car turned into a road tortoise on hill. It revs without flooring the gas pedal.
  11. Gloria&Suzanne
    81
    Sacramento, CA
    It went into full limp mode, nearly stalling my vehicle.
  12. Gloria&Suzanne
    81
    Sacramento, CA
  13. Gloria&Suzanne
    81
    Sacramento, CA
    The oil pan needs new sealant. I was talking about an incident where Google maps took me on a dangerous stretch of Highway 49 in Northern California, USA, in the mountains. Roads were narrow, hills were steep, some blind turns.
  14. Gloria&Suzanne
    81
    Sacramento, CA
    I'm not that dumb. I don't wanna go rough on my baby (My Prius which I named Suzanne). Becoming emotionally attached to non-living things as if they were living is a common experience for people on the autism spectrum, like me.
    And I'm a woman, and my 22nd birthday is coming up, so I'm not a teenager. I feel blown off as you did not witness the extent of which my car did that. You did not ride along with me. A life lesson is do not assume you fully understand someone else's lived experiences when you haven't gone through them yourself. ‍
  15. Brian1954
    2,689
    1,076
    Can you please answer the questions I asked in post #2?
  16. ChapmanF
    19,033
    Hey @Gloria&Suzanne,
    I'm very sorry that you read my post in that way, when I was replying to Higgins909. I was not replying to you in that post at all.
    If you remember back in post #5, I reassured you that a Prius won't over-rev the engine. It just won't. The engine revs are under computer control at all times.
    Higgins909 then made post #6 about the maximum RPM range the engine will reach, and I replied to that post, confirming that 5300 is the maximum RPM the car will use because power actually drops off above that point and the car knows that. The contrast between what a Prius won't do and what a (hypothetical!) teenaged driver in some other type of car might do was purely to illustrate that point.
    That hypothetical teenager for illustration purposes wasn't you or anybody else in the conversation. And, after all, the point being illustrated was that a Prius just won't do that. Even in an alternate universe where you were a teenager and tried to over-rev your Prius engine, it simply wouldn't happen.
  17. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    You may be eligible for free repair, if there's indeed a problem with the inverter. We still don't know how much it "revs," in what circumstance. To some degree is normal, even "without flooring the gas pedal."
    Let us know what the dealer says and does.
  18. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Gloria,
    What kind of stuff have you been through?
  19. Mendel Leisk
    42,354
    The oil in the intake manifold is mostly delivered by the PCV system, and aforementioned effective oil-catch-can can minimize its return. Keep in mind too, the oil pool may just be portion of the total, a significant amount might blow right through, into the combustion chambers.
  20. Brian1954
    2,689
    1,076
    She posted the following in a different thread:
