Struggling with a rear view canera
Discussion in 'Newbie Forum' started by Slim8811, Nov 11, 2017.
  1. Slim8811
    Slim8811 New Member
    Bellevue
    2015 Prius c
    I just got a Prius C 2015 and I'm trying to install a rear view camera to a stock radia and things don't add up. The camera has a 16 pin male plug in, but it doesn't fit anywhere in the radio!
    Any help is appreciated!
  2. Slim8811
    Slim8811 New Member
    Bellevue
    2015 Prius c
    IMG_1908.JPG IMG_1905.JPG IMG_1904.JPG IMG_1904.JPG IMG_1905.JPG IMG_1908.JPG Here are the pics
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    Assuming the camera is electrically compatible with the radio, you may have to remove the terminals (with the wires still attached) from the 16-position connector supplied with the camera and install them in the existing 24-position connector, G83 (Navigation Receiver Assembly) or G89 (Radio and Display Receiver Assembly):
    G83-11 or G89-11 (CA+)
    G83-12 or G89-12 (V+)
    G83-23 or G89-23 (CGND)
    G83-24 or G89-24 (V-)​
    Toyota’s Wire Harness Repair Manual (PDF, circa 2007) has the basic procedures for handling connectors, and the details specific to your car are in the Electrical Wiring Diagram, available by subscription to techinfo.toyota.com.
    Your local public library sponsors free access for its patrons to the ChiltonLibrary service, which doesn’t have the Electrical Wiring Diagram, but it does have the Terminals of ECU and DTC C1622 sections from the Repair Manual, which might give you enough information, if you already know what each wire in the 16-position connector does.
    RCO and Slim8811 like this.
  4. Slim8811
    Slim8811 New Member
    Bellevue
    2015 Prius c
    Awesome! It does look like I need a 24 pin one!
    Thanks
    RCO likes this.
