Strut bar: tanabe or cusco?
Discussion in 'Gen 3 Prius Main Forum' started by nicoj36, Mar 8, 2019.
  1. nicoj36
    nicoj36 Active Member
    518
    162
    Anyone here have tried both? If so, which one do you think is better? I'm about to install one for my 2010 which has serious swaying issues. I already installed the TRD sway bar in the rear but it did not fix my swaying so I'm looking to upgrade the suspension a little more to see if it helps. I'm also going to install a chassis brace.
    Cusco or tanabe? Ty!
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Just choose the one that you think is prettier.
    audiodave likes this.
  3. nicoj36
    518
    162
    Really. No difference in performance whatsoever?
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Just like when your deciding which lady to marry.
    Greenteapri likes this.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  6. orenji
    orenji Senior Member
    5,887
    3,488
    Tom’s Strut bar is the best. It’s one solid piece so limits flex more then Cusco or Tanabe. Hard to find, you can try Hybridpit or keep an eye out on EBay. I just picked one up for myself. Expensive but works.
  7. n23
    n23 Junior Member
    28
    Tampa, FL
    I thought about it, but when I saw that it blocks the underhood fuse panel, I changed my mind. Just what I want, to be on the side of the highway with a blown fuse and not have a ratchet set on hand to remove a strut tower bar. The risk to reward doesn't make sense for me. Now granted, it's pretty rare that I've had a blown fuse, but I'm sure that if I did, it would be in the rain at 3AM with my wife and kids in the car.
    Knightrider likes this.
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    Correct......That's why I have the CUSCO.
  9. orenji
    5,887
    3,488
    No blockage.
  10. orenji
    5,887
    3,488
  11. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I have the Cusco bar and it doesn't block the fuse box at all. Combined with the TRD rear sway bar and braces, the car actually handles very well for what it is!
    Xterra72 and orenji like this.
  12. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    My husband's and my retired aircraft engineer friend helped me install mine without having to remove the wipers and the wiper cowl.
    nicoj36 likes this.
  13. WolfpackBill
    349
    500
    Lexington, NC
    Very nice!. But if you use a power drill, it only took me an extra 15 minutes to remove all the stuff to get to the strut tower AND reinstall. It was pretty easy.
  14. nicoj36
    518
    162
    Thank you for the inputs. I think I will go with the cusco since it doesnt block the fusebox and isnt as bulky as the tanabe.
    RMB likes this.
  15. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Make sure you get the one marked LHD for left hand drive. The one made to the right hand drive Prius will not work well in a left hand drive Prius.
    RMB likes this.
  16. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Once a while eBay has a 15% coupon, use that to bring the price of a Cusco STB down to $153. That's what I did. :D
    Raytheeagle and Georgina Rudkus like this.
  17. orenji
    5,887
    3,488
    Enjoy but know that Cusco and Tanabe are more for looks then actually performance.
  18. nicoj36
    518
    162
    So you're saying these strut bars are useless? Im actually looking to use it because my prius has swaying issues specially at high speed. Combine these struts with a new sway bar links, and new tie rods. Im hoping it will cure my swaying issues. And also improve handling.
  19. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    I drove my friend's old 1998 Mazda MPV mini van, before I drove my Prius v. The OLD MPV felt a lot better than the v.
    After I had both the strut bar and the center brace, both made by CUSCO installed, there was a definite improvement in feel and handling.
    Clearly, Toyota installed three braces on the Gen 4 in 2016, instead of the one on the Gen 3 including the v.
  20. orenji
    5,887
    3,488
    I am say a solid strut bar is going to give you much more then one with attached mounting that can flex.
