Strut Change and Alignment
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cgm55082, May 28, 2013.
  1. cgm55082
    cgm55082 Junior Member
    I've gone through my new-to-me 2006 Prius with 103K on it and replaced all of the things this forum recommends, from transaxle fluid to yellow-top battery to LRR tires. The last thing I can possibly replace as preventative maintenance are the struts. They are in pretty good shape, but do make some noise on bigger hits, so I figure after 103,000 it's probably time to replace them. My question is this: How soon after replacing the struts should the alignment be done? I ask because I live about 40 miles from the dealership, where I intend to have it aligned. Is that too far to drive after changing the struts? I have new tires and don't want to do anything that could screw them up. Also, I plan to do the rears next month, but I'm assuming they won't impact alignment since I've heard the rear can't be aligned. Is this accurate?
    Thanks for all responses.
  2. Patrick Wong
    18,210
    6,515
    40 miles is not too far. Yes, the rear suspension cannot be aligned unless shims are inserted.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Patrick is as usual quite correct, but I would add that aligning the rears with shims in my opinion is well worth the effort. It gives the car greater strait line stability, improves tyre life, and can save fuel by improving or lowering the rolling resistance of the car.
    John (Britprius)
  4. cgm55082
    Thanks Patrick and John. Can the rears be aligned by the dealership, or do they not condone using shims?
  5. Britprius
    5,194
    1,922
    I assume your in the US where I believe most dealers will not carry out this work but rather change the whole rear axle. The dealer can check though if it is in alignment (within specification).
    I made some guages and did my own car finding the rear camber was at it's maximum limit on one wheel and slightly over on the other causing the tyres to ware on the inside edge. After correction with home made shims the tyres now ware very evenly.
    I believe most good alignment shops will do this however.
    John (Britprius)
  6. Britprius
    5,194
    1,922
    Should have added that there is a service tool for aligning the rear axle "although I have never seen one or found a workshop that has one" that basically bends the axle till the alignment is correct.
    John (Britprius)
  7. peterjmc
    917
    189
    Clarksburg, MD
    When I asked my dealer about them correcting it he told me that I h
    Would have to take the car to a body shop. The tool they would use is a frame straightener.
  8. Britprius
    5,194
    1,922
    That could work, but the tool I have heard about but not seen is a Toyota service tool.
    John (Britprius)
  9. peterjmc
    917
    189
    Clarksburg, MD
    Has anyone tried to replace to bushings on the rear to see I'd worn bushings are a contributor to alignment problems like out of spec toe? From what I recall there are two large bushings in the rear for the "self adjusting" toe alignment.
  10. Britprius
    5,194
    1,922
    The bushings only affect the center alignment offset. The axle beam is a one piece structure that sets toe in and camber and unless shiming is used at the wheel hubs the only adjustment is by bending the axle or fixed trailing arms. Twist in the axle gives the roll stiffness assisted by the anti roll bar.
    John (Britprius)
  11. cgm55082
    Can anyone confirm what specs the Prius should be aligned to? I thought I read somewhere that it should be aligned with zero camber, toe, etc. Is that correct? If so, it would be unusual.
  12. Patrick Wong
    18,210
    6,515
    Total Front Toe: 0 degrees, +/- 0.2 degrees
    Camber: -0.58 degrees +/- 0.75 degrees
    Right-left error 0.75 degrees or less
    Caster: 3.17 degrees +/- 0.75 degrees
    Steering axis inclination: 12.58 degrees +/- 0.75 degrees
    SDB54 likes this.
  13. cgm55082
    Thanks Patrick. Is it advised to have the car aligned at the dealer versus a reputable tire shop? Seems the dealer knows better what to do with the Prius, but don't want to make a false assumption.
  14. Patrick Wong
    18,210
    6,515
    There is nothing special about front wheel alignment so any competent shop can do the work. Only toe-in and camber can be adjusted.
    The rear wheels cannot be aligned per Toyota repair policy (if off, the recommendation is to replace the rear beam axle.) A specialist wheel alignment shop may be able to install shims in the space between the wheel hubs and the beam axle ends, to adjust rear wheel toe-in and camber.
  15. randyhuber
    randyhuber Junior Member
    Maine
    My dealer (Central Maine Toyota in Waterville, Maine) says they will install shims to correct out-of-spec rear toe.
  16. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    My local Toyota dealer shimmed the rear of my '05 a few years ago for a 4-wheel alignment and all is fine.
  17. robomoto
    robomoto Member
    78
    56
    Surrey, BC, Canada
    I just replaced my struts with KYB strut-plus in the front and Excel-G shocks in the back. They were 100% IDENTICAL in dimensions to the original parts, and the tightness with which the bolts align them meant that the replacements would produce no changes in alignment whatsoever from before. Yes the ride height will increase, but it will also gradually decrease, meaning any changes in camber will gradually reverse out. The road test confirmed absolutely no leaning or adverse handling characteristics. My tires wore fine as was. As a matter of fact, the replacement eliminated any amount of leaning and vibrations from the worn out parts. The struts also state that you should let the springs settle after installation as the ride height will be higher than normal for a while. So I see absolutely no reason to bring it in to a shop for an alignment. If I see drastically abnormal tire wear or something really crazy in the car's handling, then I will get it aligned. If your car handles fine and the tires wear fine before and after the replacement, I really don't think you should worry about an alignment after. It's a Toyota after all.
    #17 robomoto, Jan 9, 2020
  18. wlai
    wlai Junior Member
    36
    Pacific NW USA
    Just the topic I'm about to tackle...I purchased structs for replacement of front and back at 180K. I went with low cost units because the car has body damage and I'm just going to drive it till it dies. Besides alignment is there anything else I should do after the DIY structs replacement?
  19. robomoto
    robomoto Member
    78
    56
    Surrey, BC, Canada
    If you plan to drive it for any length of time then you should return your low cost struts for at least OEM quality, i.e. KYB. At 180k the drivetrain of any prius can reasonably be expected to run at least another 180K. You will save money and ride more comfortably. While I was at it I replaced the sway bar bushings and links as they were cheap and easy. You're gonna take the wheels and the upper cowl off so I'd do the spark plugs and brakes too if needed.
    wlai likes this.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Whatever you do make sure you replace the upper steering bearing on each front strut. It will be a marked change in steering effort with new bearings.
    wlai likes this.
