Strut mount movements
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by SmellyTofu, Jan 31, 2023.
  1. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    Are the strut mounts supposed to not only rotate on the horizontal axis but also change angle as you turn the steering wheel? I'm concerned my strut mounts are the cause of my suspension noise as I've checked for loose tie rod ends and loose bearing.
    This is the view at full lock to the right where it looks like the strut is leaning left
    vs full lock to the left where the strut is semi straightened up
  2. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    Strut orientation (‘angle’) will change with suspension loading and body roll, but should not change with steering angle alone, otherwise static load.
  3. SmellyTofu
    251
    29
    Sydney
    Thanks. I didn't think so they'd change angles at all especially with the front end in the air which is what the was in when I took the photos. Would you think other bushes in the lower control arm be allowing for that sort of movement?
  4. Air_Boss
    4,139
    1,154
    New Yawk
    More than bushing wear. More like a broken ball joint, tie rod end, etc.
  5. SmellyTofu
    251
    29
    Sydney
    Well the mechanic came back and said the uni joints in the steering column is along the shaft of the intermediate joint. Apparently when you change it, it needs to be calibrated which I didn't know about because as long as you get the right spline when you put the intermediate shaft back, how would the car know?
