Strut replacement question
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by Brock, Sep 15, 2012.
  1. Brock
    Brock Junior Member
    40
    I am at 80k miles, I purchased the car at 60k. It is a year 2006
    My tires are dang near bald, and I havn't changed them yet because I was told ( and showed) when I had the oil changed that my struts were getting worn (he said it by no means are they the worst I've seen, but I would replace them when you get tires so they wear evenly). Anyway, my questions is. What are the cheapest struts to get (that are OK to use)? Also , is it really around 10 dollars a strut to have the old ones removed and new ones put on? Is there a website that sells all 4 together as a package? Also what tires would you recommend for all season?
    Thanks
    Rick68 likes this.
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    You might try a search in the gen 2 forums, lots of info about strut replacement and places to obtain, whomever quoted you should be avoided in the future, 10$ per strut, did they offer a piece of candy also?
    OEM's are KYB, as are aftermarket, Gabriel also makes one that fit's, KYB is my choice, total should be 6-8 hundred including labor, but then you need an alignment unless that's included.
  3. Brock
    Brock Junior Member
    40
    oh 600-800 for struts, sounds like I'm just putting tires on this time, maybe at 100 or 125 I will get struts once they actually have no life in them
    so they really charge you like 500+ to install them?
  4. mfa-prius
    mfa-prius Old member
    299
    45
    Hansville, WA
    Ijust had all 4 done in two separate visits to a dealer. Rear struts were $96.93 for parts, $168.72 for labor (each); front were $118.78 for parts, $170.86 for labor (each); 4-wheel alignment $79.75. Total parts: $431.42, total labor: $759.11. Total: $1190.53, plus tax for everything. Since the front & rear were done on 2 separate visits, I actually had 2 4-wheel alignments. (No, they didn't toss in the 2nd for free.)
  5. Patrick Wong
    18,200
    6,479
    A waste of money to pay for a "four wheel" alignment, whether it was done once or twice, since the rear axle is not adjustable. If you desire to be cost-conscious, one front wheel alignment performed when the front struts was replaced is all that is required. When front struts are removed, the camber adjustment is thrown off.
  6. mfa-prius
    299
    45
    Hansville, WA
    So how do all these dealers get away with selling "4-wheel alignments"? Do I smell a class action opportunity?
  7. Mike500
    Mike500 Senior Member
    2,593
    764
    I'd be sure that the struts are work out. The obvious signs would be that they are leaking hydraulic fluid out at the piston rod seals.
    Internally, it would be worn out piston oil rings that would be worn out. Unless they are totally "blown away" and not there, strut performance is only degraded.
    At 140K, most shops or dealers "see you coming" as "low hanging fruit" for a sale.
    Worn out struts are not the only cause for tire wear.
    I have had vechicles with over 200k and more. The struts are really worn out, when you either feel and hear a "clunk" when driving over a speed bump and the wheel bounces several times before returning to steady.
  8. Patrick Wong
    18,200
    6,479
    Did you receive a printout that shows before and after status of your wheel alignment?
    If yes, did you notice there is no difference in the before/after status of the rear wheels, even if they are out of spec.
    If the "after" status of the rear wheels shows that they remain out of spec, I suggest you call your dealer's service writer and ask how they can justify selling you a 4-wheel alignment when nothing was done to the rear.
    HDuncan likes this.
